Side panel removal: Door won't open
edgar-s
Post27-01-2004, 21:23    Subject: Side panel removal: Door won't open Quote
Looking for a tip on how to remove the side window when the rear door is locked. Reason: the door cannot be opened, but the linkage is still moving.
It appears that the aggregate carrier cannot be removed without also removing the disk.
Next, I hope to access the lock mechanism and unlock it from the inside - or does anyone have a different idea?
Thank you, Edgar.
Translated on 07-09-2026, 17:53.
christians
Post27-01-2004, 22:03    Subject: Side panel removal: Door won't open Quote
I would partially disassemble the intact door on the opposite side to get my bearings. Perhaps you can use a wire to reach parts of the lock between the glass and the door frame if you know where you need to go.
Gruß Christian
98er_alh
Post27-01-2004, 22:35    Subject: Side panel removal: Door won't open Quote
I may not fully understand the problem, but perhaps this will help?
Andreas.
Translated on 07-09-2026, 17:54.
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts Glow Plug Not Turning Off? Engine Won't Start. Diesel Engine Technology
No new posts Error reading failed On-Board Diagnostics (OBD)
