HEX-V2: Login failed (Solution)
ebulagti
Post05-05-2019, 12:18    Subject: HEX-V2: Login failed Quote
Hello
I've acquired the HEX-V2. Software 18.9.1 DRV
Wanted to install a trailer hitch.
The car is an Audi Q2, manufactured in 04/19.
But no matter what I do, it's not working.
When logging in, an error message always appears: "Stg sends no SEED" or, when encoding, the message "Fingerprint WSC ... rejected".
Error memory reading function.
I am feeling a bit lost.
Post05-05-2019, 12:46    Subject: HEX-V2: Login failed Quote
Where is the Autoscan? Have you noticed that your car is newer than the diagnostic software being used?
Best regards, Rainer
ebulagti
Post05-05-2019, 13:10    Subject: HEX-V2: Login failed Quote
Here is the car scan
Log-WAUZZZGAXKA033386-6688km.txt
 File name:  Log-WAUZZZGAXKA033386-6688km.txt
 File size:  15.25 KB
 Downloaded:  1464 times
Post06-05-2019, 17:18    Subject: HEX-V2: Login failed Quote
Please...
1 Error found:
66304 - Data Bus
U1124 00 [009] - Multiple stacking detected
[Multi-layer CAN]
Confirmed - Verified since last deletion
Environmental Conditions:
Error Status: 00000001
Error Priority: 2
Frequency of Errors: 1
Lost Count: 75
Mileage: 6688 km
Date: 2019.05.05
Time: 14:03:41
Clear fault codes / Check parts list.
Regarding the seed issue, please contact Ross-Tech USA support: support at ross-tech.com
ebulagti
dieselschrauber likes this.
Post14-05-2019, 11:24    Subject: HEX-V2: Login failed Quote
Hello
The hood must be open in order for it to function.
Since then, everything has been perfect.
Post19-05-2019, 7:26    Subject: HEX-V2: Login failed Quote
Ratings - HEX-V2: Login failed
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding a used odometer, login code unknown... On-Board Diagnostics (OBD)
No new posts Label File Redirection Failed On-Board Diagnostics (OBD)
No new posts Golf V 1.4 Gasoline GRA retrofit failed Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf 4, year 2003 - KOBD2Check - Operation failed On-Board Diagnostics (OBD)
