Tire Circumference Calculator - Calculate Tire Size
garth.brooks
Post20-01-2004, 14:56    Subject: Tire Circumference Calculator - Calculate Tire Size Quote
Hello everyone,
I found a tire circumference calculator online.
http://www.golf3.de/reifen.html
It's particularly helpful if you want to register different tires.
Translated on 27-09-2026, 16:13.
Gremlin
Post22-01-2004, 8:04    Subject: Tire Circumference Calculator - Calculate Tire Size Quote
I just quickly calculated that.
Based on the data from this device, you will get the exact speed displayed on the speedometer (using engine speed as a basis), with precise readings for all gears, etc.
-> Since the actual speed is definitely lower, the calculator likely includes the speedometer reading. Be careful!
Does anyone have measured tire dimensions for 195/65 R15 tires?
CU Gremlin.
Translated on 27-09-2026, 16:14.
Diesel-Dirk
Post22-01-2004, 8:28    Subject: Tire Circumference Calculator - Calculate Tire Size Quote
The calculation is based on a very simple formula.
((Diameter * 25.4 + 2 * (Width * Height / 100)) * 3.1416) / 10
Okay, bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
bitsch1m
Post22-01-2004, 17:31    Subject: Tire Circumference Calculator - Calculate Tire Size Quote
Why is tire width included in the calculation of the overall diameter?
It shouldn't matter.
Hi Michael,
Translated on 27-09-2026, 16:15.
Jan6K
Avatar-Jan6K
Post22-01-2004, 17:53    Subject: Tire Circumference Calculator - Calculate Tire Size Quote
The width is not arbitrary because the height is not absolute, but relative to the width.
A 185/55/15 is 185 mm wide, and 55% of 185 mm high. That's why it's needed, as you can see from the formula icon_wink.gif.
Otherwise, the formula is nonsense because it does not take into account either the permissible tolerance or the deformation caused by the vehicle's weight.
Ulfs formula (on page 2 of the DZR) is better.
Jan.
1Z5 CFHF / AHB H4D
Translated on 27-09-2026, 16:16.
Gremlin
Post22-01-2004, 19:59    Subject: Tire Circumference Calculator - Calculate Tire Size Quote
but still slightly above the values of Climatronic and traffic signs.
Okay, I guess I'll have to get out the measuring tape after all...
CU Gremlin.
Translated on 27-09-2026, 16:17.
No new posts for calculation Diesel Engine Technology
No new posts Wastegate Calculation: Formula & Guide Diesel Engine Technology
No new posts TDI Performance Measurement: Calculating the Nominal Perf... Diesel Engine Technology
No new posts BBY: Incorrect calculation of motor torque Gasoline Engine Technology
