Side panel removal: Door won't open
edgar-s
Post27-01-2004, 21:23    Subject: Side panel removal: Door won't open Quote
Looking for a tip on how to remove the side window when the rear door is locked. Reason: the door cannot be opened, but the linkage is still moving.
It appears that the aggregate carrier cannot be removed without also removing the disk.
Next, I hope to access the lock mechanism and unlock it from the inside - or does anyone have a different idea?
Thank you, Edgar.
Translated on 07-09-2026, 17:53.
christians
Post27-01-2004, 22:03    Subject: Side panel removal: Door won't open Quote
I would partially disassemble the intact door on the opposite side to get my bearings. Perhaps you can use a wire to reach parts of the lock between the glass and the door frame if you know where you need to go.
Gruß Christian
98er_alh
Post27-01-2004, 22:35    Subject: Side panel removal: Door won't open Quote
I may not fully understand the problem, but perhaps this will help?
Andreas.
Translated on 07-09-2026, 17:54.
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts The pre-heating lamp is not turning off. Motor does not s... Diesel Engine Technology
No new posts Error reading failed On-Board Diagnostics (OBD)
