Diagnosis of PDA?
vagtuning
Post13-02-2004, 23:39    Subject: Diagnosis of PDA? Quote
Has anyone found a well-functioning and cable-compatible version similar to VAGCOM for a PDA?
Trying to install VAGCOM directly onto a 2003 Mobile PDA will likely fail, and besides, there doesn't seem to be a way to connect it to the cable.
Are there adapters that convert from a serial port to a standard COM cable? And would that even work?
Translated on 22-07-2026, 7:54.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts K-Line Diagnostics via USB On-Board Diagnostics (OBD)
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
No new posts OBD II Tuning: How to Tune Your Car Diesel Engine Technology
No new posts Measure oil temperature using MFA Transmission, Chassis, Body & Interior
