VAG error 17970 and a few questions
xkrzysx
Post21-01-2004, 13:12    Subject: VAG error 17970 and a few questions Quote
Hello!
It started like this: first, the indicator light started blinking.
My VAG workshop read the error codes, and error code 17970 came up.
I've already read through the entire community forum and only found one thing - N146 is blocked.
Unfortunately, the people in my workshop don't know what to do. (I wonder if the repair manuals are just as limited east of the Oder River? icon_cry.gif) I don't have a chip or a box. Please help me, because no one knows what to do. Where should I look for the problem, and how can I get N146 working again?
Thank you.
/Chris
Karma: +784 / -0   Thank you, like it!
Post21-01-2004, 13:42    Subject: VAG error 17970 and a few questions Quote
Possible causes:
Quantity setting (N146) defective/blocked.
Upper limit reached
If the engine is still running, pour a generous amount of diesel cleaner into the nearly empty fuel tank.
Otherwise, check the control devices, flow meters, and electrical wiring.
In the worst-case scenario, it may be necessary to replace the fuel injection pump.
xkrzysx
Post21-01-2004, 13:45    Subject: VAG error 17970 and a few questions Quote
The engine runs quite well; it doesn't misfire or sputter. The fuel consumption is also fine. The problem is intermittent, occurring maybe once or twice a week. I'm going to try using a diesel cleaner. Which one would you recommend?
Gremlin
Post22-01-2004, 8:59    Subject: VAG error 17970 and a few questions Quote
Are things as simple as tuning boxes, 10-cent items, or biodiesel excluded?
CU Gremlin.
xkrzysx
Post23-01-2004, 0:05    Subject: VAG error 17970 and a few questions Quote
Hello!
As I mentioned earlier, no changes were made to the engine management system. Okay, so no modifications to the exhaust system and no '10c tuning.'
Now I'm waiting until the tank is almost empty and I'm going to try using this diesel cleaner.
The funny thing is, this problem occurs very irregularly. Sometimes everything is fine for a few days, and then it starts blinking for a while (sometimes for 5 minutes), and the next time you start it, everything is okay again.
xkrzysx
Post23-01-2004, 0:07    Subject: VAG error 17970 and a few questions Quote
Okay, here's the translation:
'Just one more thing!'
I can't rule out biodiesel, but could that be the reason for this error? Well, you all know very well how the diesel quality is with us...
Post23-01-2004, 10:19    Subject: VAG error 17970 and a few questions Quote
Well, it doesn't have to be that way...
xkrzysx
Post23-01-2004, 12:18    Subject: VAG error 17970 and a few questions Quote
Furthermore, I don't plan to disassemble the ESP. Well, determining the correct answer might be easy, but putting it all together... icon_confused.gif
xkrzysx
Post26-01-2004, 16:50    Subject: VAG error 17970 and a few questions Quote
Today, I started by adding a 'generous' amount of diesel cleaner to the tank, let's see if it works. I will describe the results.
Thank you for the tip.
xkrzysx
Post29-01-2004, 15:10    Subject: VAG error 17970 and a few questions Quote
Hey everyone!
I think the tip about using a diesel cleaner worked! The error seems to have stopped occurring. icon_biggrin.gif Thank you very much again!
Post29-01-2004, 15:12    Subject: VAG error 17970 and a few questions Quote
What was the name of the cleaning product?
xkrzysx
Post01-02-2004, 11:52    Subject: VAG error 17970 and a few questions Quote
The cleaner was from STP (like that blue bottle icon_wink.gif).
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0148 - Fuel Supply Malfunction General Tips
No new posts A few questions (I'm a diesel newbie) Questions about que... Diesel Engine Technology
No new posts Spur einstellen! Ein paar Fragen! Transmission, Chassis, Body & Interior
No new posts Hallo erstmal!! Und gleich ein paar Fragen Diesel Engine Technology
No new posts Ein paar Fragen wegen NW-Einstellung beim PD Diesel Engine Technology
