Honda Accord Injector: 2.0TD, 1997 Model
Hawaii
Post27-01-2004, 11:23    Subject: Honda Accord Injector: 2.0TD, 1997 Model Quote
I had to replace an injector on my Honda Accord 2.0 TD and installed a used one. Now the engine is knocking, but it seems to be performing normally in everyday driving.
It's possible that I didn't adjust something correctly during assembly (the nozzle was disassembled). Inside the injector, there's a kind of thick disc (about 5mm high) with small holes and pins.
Can someone icon_eek.gif give me a tip?
Sure, here's the translation:
'Best regards,' or 'Sincerely,' (depending on the context).
Robert.
Translated on 07-08-2026, 6:02.
Uli S.
Post28-01-2004, 18:33    Subject: Honda Accord Fuel Injector - 2.0TD 1997 Quote
Hawaii wrote:
Could it be that I didn't adjust something correctly during assembly (the nozzle was disassembled)? Inside the injector, there is a kind of thick disc (about 5mm high) with small holes and pins.
"There's nothing adjustable on this injector, but simply replacing the nozzle without adjusting the opening pressure can cause the engine to knock because it might lead to after-injection in that cylinder. If even the smallest piece of debris gets inside, it can cause the injectors to seize, which will sound like a broken connecting rod bearing."
The pressure is adjusted using washers of varying thicknesses, which are located at the very back of the upper part of the nozzle holder and pre-tension the spring to a greater or lesser extent. In practice, this looks like this:
- Disassemble the nozzle holder, remove the old nozzle, insert the new one, and reassemble.
- Check the opening pressure (you'll need a testing device for this). If it's incorrect, disassemble again, remove the spring, and carefully pry out the shim.
- If the pressure is too low, use a thicker shim; if it's too high, use a thinner one. As a general rule for my VW injector holders, a difference of 0.05mm in shim thickness results in approximately 3 bar of pressure change.
- Assemble the nozzle holder with a torque of 70 Nm.
- After a test run, if the injector holder is leaking, you have to take everything out again and tighten the injector holder with 100 Nm or so (which isn't supposed to be done, but I do it anyway). If it's still leaking, disassemble it again, lap the conical washer on a glass plate using 1200 grit sandpaper with oil, as well as the mating surfaces in the injector holder. Rinse everything thoroughly and reassemble *grrr*. And then hope that it's finally sealed...
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 07-08-2026, 6:05.
Hawaii
Post29-01-2004, 8:19    Subject: Honda Accord Injector: 2.0TD, 1997 Model Quote
'Thank you!'
I'm going to play around this weekend.
Translated on 07-08-2026, 6:08.
No new posts Airbag sensor issues, 1997 model, type 1H1 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts Automatic Transmission Fluid Change 01M Golf III Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Honda Accord Fuel Injector Assembly Diesel Engine Technology
No new posts Fuel Injector 0434250071 - Buy Now! Diesel Engine Technology
No new posts Einspritzdüse Sdi und Tdi gleich? Diesel Engine Technology
No new posts Injector Removal: A Hard Case Diesel Engine Technology
