B4 Tie Rod: Function & Purpose Explained
palmstrollo
Post10-03-2004, 15:54    Subject: B4 Tie Rod: Function & Purpose Explained Quote
Hi.
After receiving a suggestion in another thread, where I had mentioned the possibility of a broken tie rod end or a defective strut mount, I received a comment pointing to a potential defect in the stabilizer link. icon_question.gif icon_question.gif icon_question.gif This led me (and now you) to question the purpose or function of these stabilizer links.
So: What is the purpose of the tie rod, and how does it work? What are the symptoms of a faulty tie rod? How is it replaced?
Thank you and best regards.
Hermann.
Translated on 08-10-2026, 3:51.
Wolfgang
Post10-03-2004, 18:19    Subject: B4 Tie Rod: Function & Purpose Explained Quote
The stabilizer bar connects to the wheel suspension via a tie rod.
The stabilizer is a U-shaped 'rod' that counteracts the tendency of a wheel to dip in on one side, while not significantly hindering the normal, even dipping on both sides. This helps to counteract the vehicle's tendency to lean outwards in curves.
In earlier models (e.g., Golf 1 and 2), the stabilizer (as it is affectionately called icon_smile.gif) was simply attached to the lower control arm and the lateral links.
In the current models, it is located higher up in the engine compartment and is connected to the wheel suspension (specifically, to the shock absorber located below the spring) via tie rods.
Translated on 08-10-2026, 3:52.
palmstrollo
Post10-03-2004, 18:36    Subject: B4 Tie Rod: Function & Purpose Explained Quote
Hi Wolfgang.
Okay, so it's just a different type of mounting compared to the 'old' rubber bushings found in cars like the Golf. It definitely has nothing to do with my problems when starting the car.
Thank you.
Hermann.
Translated on 08-10-2026, 3:54.
haehnlein
Post10-03-2004, 22:22    Subject: B4 Tie Rod: Function & Purpose Explained Quote
palmstrollo wrote:
That definitely has nothing to do with my problems when starting.
I would also say that...
____________
Kein Auto mehr!
Julian
Post11-03-2004, 10:18    Subject: B4 Tie Rod: Function & Purpose Explained Quote
Hmm, so, Hermann...
Okay, here's a simple question/equation:
B4 + Winter tires + outdoor temperature around 0°C + wet conditions = traction problems.
Do you think that will work, before you realize that your volume knob on the radio is underweight...? icon_eek.gif
Translated on 08-10-2026, 3:55.
palmstrollo
Post11-03-2004, 10:31    Subject: B4 Tie Rod: Function & Purpose Explained Quote
@Julian
'Smart aleck. No one will be surprised if he experiences traction problems when starting off and accelerating hard with this setup.'
However, if even gentle acceleration in wet conditions causes the front wheels to spin (which was already a problem during the summer!), then that's definitely something worth investigating, right?
I believe I also expressed that in the relevant thread.
Hermann.
Translated on 08-10-2026, 3:56.
Julian
Post11-03-2004, 16:02    Subject: B4 Tie Rod: Function & Purpose Explained Quote
@Julian
'Smart aleck. No one will be surprised if he experiences traction problems when starting off and accelerating quickly with this setup.'
However, if even gentle acceleration in wet conditions causes the front wheels to spin (which was already a problem in the summer!), then that's definitely something worth investigating, right?
Hermann
Hm, you're the one who's being a jokester, but I guess there has to be someone like that. icon_wink.gif
What kind of tires are you using (size, brand)?
Translated on 08-10-2026, 3:57.
palmstrollo
Post11-03-2004, 16:29    Subject: B4 Tie Rod: Function & Purpose Explained Quote
Tire size 205/60, mounted on a 10-spoke series wheel. These are Barum budget tires.
Why?
However, this problem has also been occurring for 1 1/2 years, even with winter tires or Uniroyal summer tires.
Translated on 08-10-2026, 3:58.
faz
Avatar-faz
1994 Audi 80
Post17-03-2004, 21:27    Subject: B4 Tie Rod: Function & Purpose Explained Quote
Should I retrofit EDS?
With the ABS/EDS unit and the corresponding ABS control module, you should be able to find a solution. Perhaps you can find a used one.
MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 08-10-2026, 3:59.
No new posts LMM Filter: What is it and what does it do? Diesel Engine Technology
No new posts Stabilizer Bar Link Torque Specs Golf 3 Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Downshifting: Why Reduce Speed Before Stop? Diesel Engine Technology
No new posts RCD500 CD Changer: Installation & Guide Transmission, Chassis, Body & Interior
