chris11 Profi-Schrauber
Joined: 10/02/2002 Posts: 326 Karma: +3 / -1 Location: Münster
02-02-2004, 21:25 Subject: Tachometer Manipulation: Protection & Prevention |
I'm looking for a used car (preferably a 1Z model, possibly a station wagon, with a tow hitch). Unfortunately, it's quite easy to manipulate the mileage these days. The potential profit from reselling seems to often outweigh any moral concerns.
As a used car buyer, what options do I have beyond the usual things like the service history booklet, wear and tear on the seats, windshield, and pedal covers? These can all be replaced, and it's often very difficult to get reliable information when buying from a second owner.
I am grateful for any advice.
Christian.
Translated on 19-08-2026, 9:43.
Julian Guest
02-02-2004, 22:40 Subject: Tachometer Manipulation: Protection & Prevention |
Check for completed workshop visits/recalls at a dealership. If applicable, the mileage will also be recorded during repairs.
Translated on 19-08-2026, 9:44.
matthiasTDI96 Profi-Schrauber
03-02-2004, 16:27 Subject: Tachometer Manipulation: Protection & Prevention |
Get a laptop and an OBD cable, unpack it, and ask if you can quickly check everything to make sure it's working correctly. Casually mention that it would be easy to manipulate the mileage with this method and see how he reacts. If he gets nervous, it's likely his car; if he doesn't seem to care, there are two possibilities: either he knows that the mileage on a 3-series with engine code 1Z cannot be manipulated via OBD, or he has a clear conscience. It's not a foolproof test, but you have to pull out all the stops these days to avoid being ripped off.
...and it's best not to buy them from the flag vendor on the side street...
Translated on 19-08-2026, 9:45.
03-02-2004, 17:28 Subject: Tachometer Manipulation: Protection & Prevention |
Hello MattiasTDI96,
I got an adapter for VAG.COM from [email protected]. It works great with a USB adapter on an XP laptop. However, only someone who knows what they're doing realizes that you can only read the (possibly manipulated) mileage data. Are there any other tricks? With BMW, the mileage is still stored in the light module.
With VAG.COM, it is possible to read the mileage from some diesel engine control units. If this value differs from the reading on the speedometer, I would be concerned.
While it can be manipulated, it requires expertise in at least two areas.
Is there perhaps another counter or something similar that could provide further information?
Christian.
Translated on 19-08-2026, 9:47.
joergs Guest
03-02-2004, 17:56 Subject: Tachometer Manipulation: Protection & Prevention |
How old does the vehicle appear if it still has a mechanical odometer?
I seem to recall that the engine control unit (ECU) contains a measurement value related to the engine's operating hours. With an average speed of 50 km/h, one should be able to estimate the distance traveled based on this information.
I hope this works for the 1Z as well!
Translated on 19-08-2026, 9:49.
WarLord Guest
03-02-2004, 21:55 Subject: Tachometer Manipulation: Protection & Prevention |
Firstly, he knows that with a 3-series car and a 1.0 engine, the mileage displayed via OBD cannot be manipulated.
Don't write that. There are already enough people online who offer such services. Apparently, it works quite well. The van also has a diagnostic connector (the 4 pins on the back).
Best regards, WarLord.
Translated on 19-08-2026, 9:50.
04-02-2004, 0:05 Subject: Tachometer Manipulation: Protection & Prevention |
Well, that's news to me, but I'm always willing to learn something new. Okay, it was just a suggestion anyway, and I wouldn't rely on it.
I think it's always important to also consider the following:
People who drive diesel cars tend to be those who travel more kilometers per year.
For me, a reasonable mileage usually starts around 15,000 km. If I see a Golf TDI from the year 1995 with 89,000 km on the odometer, that's when alarm bells start ringing. Anyone who drives less than 10,000 km per year probably doesn't understand something about car ownership.
Otherwise, I'm not an expert, but because I drive a lot and have owned quite a few cars myself, I would say that I can roughly estimate the mileage of a car after a thorough inspection. Of course, it won't be accurate to within 10,000 km, but you can usually tell whether a car has 150,000 km or 80,000 km on it.
It's great when people try to freshen up an engine bay that hasn't been particularly well-maintained by using a high-gloss sealant. However, I won't accept payment from such customers.
You could also talk to the previous owners, especially if there have been several.
And if you have even the slightest doubts, don't buy it at all, because trying to fix something later can quickly become very expensive.
Translated on 19-08-2026, 9:52.
DocSnydor Guest
04-02-2004, 9:38 Subject: Tachometer Manipulation: Protection & Prevention |
Generally, only people who drive more kilometers per year choose diesel vehicles.
Except for Ulf  .
But I like your idea. Because most of the sellers (who actually manipulated things) will probably start with this one  first. And then they'll start messing around...
You could always do something a little more important and type the vehicle identification number (VIN) somewhere. Make a really big show of it...
Translated on 19-08-2026, 9:54.
Andy Guest
04-02-2004, 10:58 Subject: Tachometer Manipulation: Protection & Prevention |
Hi.
So, I've also had good experiences with that tour  .
It was only a Golf 3 gasoline car at the time, which I was supposed to inspect for a friend, but the owner's eyes got wider and wider as I arrived with my laptop and wanted to quickly check the error memory.
Then, suddenly, the father also came out of the hut and wanted to see what was going on.
Best regards, Andy.
Translated on 19-08-2026, 9:56.
04-02-2004, 16:54 Subject: Tachometer Manipulation: Protection & Prevention |
"For me, it's a completely legitimate thing to do. If I want to buy a car, the owner has to agree, especially if they have a clear conscience and want to get rid of it. Otherwise, it might be better to call the police directly. I really feel sorry for people who scrape together all their money and then get ripped off simply because they don't know any better."
"Speeding violations are therefore not a minor offense."
Translated on 19-08-2026, 9:57.
Gremlin Guest
04-02-2004, 18:24 Subject: Tachometer Manipulation: Protection & Prevention |
For me, the mileage at which I start to be concerned usually begins around 15,000 km. If there's a Golf TDI from the year 95 with 89,000 km on the odometer, then the alarm bells start ringing.
Don't say things like that...
We have a customer who drives 3,000 to 5,000 kilometers per year and wants a diesel car. He insists on having a diesel; that's final.
An elderly woman owned a 25-year-old Opel Rekord. It went for its mandatory technical inspection (TÜV) every two years, but in between, it rusted away in the garage. The main thing was to have the car, registered, and roadworthy. 55,000 kilometers after 25 years!!!
Okay, it doesn't necessarily have to be attempted fraud, but there are other indicators of the mileage besides just the odometer...
CU Gremlin.
Translated on 19-08-2026, 9:59.
04-02-2004, 19:30 Subject: Tachometer Manipulation: Protection & Prevention |
Hi Gremlin, sure there might be something like that, but it's probably an exception. So, if I were only driving around 5,000 km a year, a moped would suffice, but it would be too bad to use a diesel engine for such low mileage. I just mentioned that as a rough guideline. Mine manages between 35,000 and 40,000 km per year, so I'm well above the average I quoted...and I won't drive even one more kilometer!
Translated on 19-08-2026, 10:01.
