Golfdriver Guest
07-02-2004, 21:13 Subject: VAG-Com measurement, please provide expert advice |
After replacing the diesel filter and thoroughly checking all the lines without improving the rough running issue on my 1Z, I did another diagnostic run today. Could you please take a look at the data and let me know if you can identify anything from it?
http://people.freenet.de/Fenepage/Test3.xls
http://people.freenet.de/Fenepage/Test2.xls
http://people.freenet.de/Fenepage/Test1.xls
Thank you.
Translated on 13-07-2026, 21:52.
08-02-2004, 11:12 Subject: VAG-Com measurement, please provide expert advice |
The curves seem generally "subtle" to me.
Except for the air mass readings, which are often above the expected range -> Is there a problem with the EGR valve or is it sticking?
Have you already read "everything" about stuttering/jerky movements and how to fix them here?
-> NHG and injection start logs?
Translated on 13-07-2026, 21:53.
Profile PM Garage |
Golfdriver Guest
08-02-2004, 13:42 Subject: VAG-Com measurement, please provide expert advice |
Here's a log showing the start of injection (before the diesel filter change).
http://people.freenet.de/Fenepage/Log-12-01-04.xls
and one more from the same day.
http://people.freenet.de/Fenepage/Log2-12-01-04.xls
Translated on 13-07-2026, 21:54.
08-02-2004, 15:31 Subject: VAG-Com measurement, please provide expert advice |
Sure.
Your box can't arrive that early, no matter how much it wants to.
So, the start of the injection should happen much earlier than it currently does.
Only when idling at the beginning does yours achieve -3.1 degrees; mine never does.
see:
Okay, I'm ready. Please provide the German text you want me to translate into English.
Profile PM Garage |
Golfdriver Guest
08-02-2004, 16:48 Subject: VAG-Com measurement, please provide expert advice |
and what does that mean?
Is that the reason for the stuttering/lagging?
What can be done about it?
Translated on 13-07-2026, 21:55.
08-02-2004, 16:59 Subject: VAG-Com measurement, please provide expert advice |
Golfdriver wrote: | and what does that mean?
Was kann man dagegen tun?? |
Solution: Adjust the pump settings to compensate for the late timing.
Effect: Possibly slower warm-up time and less "bite" (torque) in the lowest load range.
I doubt that it will significantly reduce the stuttering.
Translated on 13-07-2026, 21:56.
Profile PM Garage |
Golfdriver Guest
08-02-2004, 17:34 Subject: VAG-Com measurement, please provide expert advice |
How can I identify and fix the cause of the stuttering/jerky movement?
I don't want to take the TDI to a workshop and pay a lot of money, only to end up with no successful result!
Translated on 13-07-2026, 21:57.
08-02-2004, 18:49 Subject: VAG-Com measurement, please provide expert advice |
Golfdriver wrote: | | Wie komme dann dem Ruckeln auf die Spur?? |
Perhaps by trying everything that the local technical articles and error database entries suggest.
Translated on 13-07-2026, 21:58.
Profile PM Garage |
