No Downpipe Needed: Turbo Performance Boost
noxinu
Post02-02-2004, 20:38    Subject: No Downpipe Needed: Turbo Performance Boost Quote
Hi there.
When I disassembled the AFN engine for the first time, I noticed that there is no gasket provided between the exhaust manifold and the turbocharger.
Does anyone still have something suitable?
Translated on 13-10-2026, 8:06.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post02-02-2004, 23:40    Subject: No Downpipe Needed: Turbo Performance Boost Quote
hello
I was also surprised that there was nothing in between.
Clean the surfaces thoroughly and assemble them carefully, if possible.
Tighten them evenly so that they lie flat and smooth. They are usually 100% leak-proof.
Why do you want to interfere? icon_arrow.gif Can't you just let it happen? icon_eek.gif
Translated on 13-10-2026, 8:07.
Karma: +807 / -0   Thank you, like it!
Post03-02-2004, 10:00    Subject: No Downpipe Needed: Turbo Performance Boost Quote
There are special high-temperature resistant sealing pastes available for such connections.
I can't quite recall the name of the product icon_confused.gif, but I do know that it's not good to use for "cold" sealing surfaces, as it will never harden properly.
Translated on 13-10-2026, 8:08.
haehnlein
Post03-02-2004, 11:22    Subject: No Downpipe Needed: Turbo Performance Boost Quote
What is the exhaust gas pressure at this point under full load? It's certainly not particularly high icon_confused.gif.
____________
Kein Auto mehr!
Post03-02-2004, 17:09    Subject: No Downpipe Needed: Turbo Performance Boost Quote
Hi Christian,
"It probably depends on the scale... after all, the much-mentioned exhaust back pressure is located at the inlet of the turbocharger, and the pressure difference between this back pressure and the outside pressure is what the turbocharger needs in order to function at all."
And if you look at the power output from the charger (roughly 20 horsepower, if I remember correctly from a previous thread), then the charger will definitely need a few hundred mbar (or hP) of input pressure. icon_rolleyes.gif icon_question.gif
Translated on 13-10-2026, 8:09.
haehnlein
Post04-02-2004, 12:37    Subject: No Downpipe Needed: Turbo Performance Boost Quote
Hi Ulf,
A few hundred mbar ( icon_question.gif ) are not suitable for a metal pressure connection; in this case, a seal can really be omitted. At this point, it probably doesn't matter if an exhaust bubble occasionally escapes to the outside, given this flow rate. However, one could also ask why a seal is installed between the turbocharger and the downpipe. icon_confused.gif Perhaps it has something to do with the vibrations from the exhaust system. icon_question.gif
____________
Kein Auto mehr!
Translated on 13-10-2026, 8:10.
Gremlin
Post04-02-2004, 17:16    Subject: No Downpipe Needed: Turbo Performance Boost Quote
I just wanted to mention that my beloved Hercules K50-Ultra didn't even have a head gasket. It just had an O-ring to prevent the coolant from leaking in.
If everything goes according to plan... no problem.
CU Gremlin.
Translated on 13-10-2026, 8:11.
mersente
Post08-02-2004, 23:04    Subject: No Downpipe Needed: Turbo Performance Boost Quote
Hello, if everything is as planned, as I already said, everything is no problem. With my second car, the 'Ente,' there's also no head gasket issue. Just apply a high-temperature resistant paste, like copper paste, between the surfaces, and it will be fine. icon_smile.gif
Translated on 13-10-2026, 8:12.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Doku Polo MJ 2002, No Power Steering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust Manifold Gasket: Turbo to Cylinder Head Diesel Engine Technology
No new posts Turbo Failure: No More Power? Diesel Engine Technology
No new posts Turbo Adapter for Exhaust Manifold Diesel Engine Technology
No new posts VA Screw in Manifold: How to Remove? Diesel Engine Technology
