Oil Pressure Monitoring for PD Engines
Go to page: 1, 2, 3  Next
Post17-02-2004, 19:00    Subject: Oil Pressure Monitoring for PD Engines Quote
Hello everyone,
I have unfortunately obtained an incorrect wiring diagram for my ASZ Polo (which will be registered on February 19th icon_razz.gif icon_biggrin.gif). It's a diagram for the ATD/AXR engine. I'm initially assuming that the ASZ engine differs from it only in minor details.
The SLP only shows one oil pressure sensor, while the AFN, for example, has two sensors (one on the pump and one on the transmission), whose signals are evaluated based on engine speed.
Does anyone know why they've reverted to the primitive one-switch solution for PD motors, and how the evaluation process works?
Translated on 13-09-2026, 11:46.
Gremlin
Post17-02-2004, 19:11    Subject: Oil Pressure Monitoring for PD Engines Quote
The basic output circuits also include ASV and ALH.
The switch is a normally closed switch (it connects to ground when 'pressure OK'). If there is no oil pressure at approximately 1700 RPM, an alarm will be triggered.
Here, it's easy to check; simply disconnect the cable and provide the speed.
I suspect the reason for the return of the one-switch solution is simply money.
Furthermore: millions of engines have absolutely no problems with this type of monitoring icon_wink.gif.
I just wonder, 'Why do they need two oil pressure switches? Could there have been a flaw in the engineering?'
CU Gremlin.
Translated on 13-09-2026, 11:48.
Jan6K
Avatar-Jan6K
Post17-02-2004, 19:38    Subject: Oil Pressure Monitoring for PD Engines Quote
Hi Ulf,
While not directly related to the topic...
He will be approved on February 19th.
...but we're expecting a very detailed report, right?
Jan.
1Z5 CFHF / AHB H4D
Translated on 13-09-2026, 11:49.
joergs
Post17-02-2004, 20:49    Subject: Oil Pressure Monitoring for PD Engines Quote
hey ulf,
Now things are getting serious, or what? And the much-hated PD will soon be on the farm. icon_cool.gif
My 96kW PD engine also only has one oil pressure sensor. It has been working perfectly so far.
Translated on 13-09-2026, 11:50.
Post17-02-2004, 20:56    Subject: Oil Pressure Monitoring for PD Engines Quote
ulf wrote:
... I have unfortunately managed to obtain a faulty wiring diagram, specifically for the ATD / AXR engine.
Why is it wrong, I have an AXR icon_wink.gif icon_biggrin.gif?
Normally, yours shouldn't be too different from that.
Translated on 13-09-2026, 11:51.
joergs
Post17-02-2004, 21:10    Subject: Oil Pressure Monitoring for PD Engines Quote
@bertil,
We can only hope that our ULF doesn't have the same problems as you do. Otherwise, he'll be jumping out of his pants! icon_rolleyes.gif
Post17-02-2004, 21:38    Subject: Oil Pressure Monitoring for PD Engines Quote
joergs wrote:
@bertil,
We can only hope that our ULF doesn't have the same problems as you. Otherwise, he'll be jumping out of his pants! icon_rolleyes.gif
Ouch, I wouldn't wish that on him.
Translated on 13-09-2026, 11:52.
Post17-02-2004, 22:20    Subject: Oil Pressure Monitoring for PD Engines Quote
Gremlin wrote:
The switch is a normally closed contact (it switches to ground when "pressure OK"). If there is no oil pressure at approximately 1700 rpm, an alarm will be triggered.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
besides: furthermore, millions of engines have absolutely no problems with this type of monitoring icon_wink.gif
Hi Ralf,
With this solution, in my opinion, you can let a motor idle until it fails, without any warning, icon_eek.gif icon_question.gif icon_evil.gif.
So, for example, if someone icon_evil.gif messes up an oil change and doesn't put in new oil, and then drives the car at low RPMs... -> goodbye, engine icon_twisted.gif.
@JanViewing profile: Jan:
What kind of report are you expecting?
Blah blah about how great and how beautiful and how (not) equipped it is - that's actually not what I wanted to introduce here new_tomato.gif.
Once it's broken in, I can provide some performance data, such as acceleration times. Before that, if you're interested, I can share some initial data, for example, about the transmission (RPM vs. km/h) or similar information.
Otherwise, perhaps about aggressive behavior in polo ponies (hopefully not).
Well, we'll see.
But of course, I'm still curious.
Here's a little something to look forward to regarding the price list:
I had expected that the standard ESP system would be deactivated and that I would retain the ASR and EDS functions, which should have been indicated by a corresponding "ASR Off" switch.
However, there is no switch, and therefore it is likely "just" ABS, which is the minimum standard equipment.
I probably would have had to re-order the ASR (for 200 Euros) after canceling the ESP (saving 250 Euros).
But that probably wouldn't have been possible, because "ASR: not available for 74 and 96 kW engines, as it is standard equipment" }.
Translated on 13-09-2026, 11:55.
Gremlin
Post17-02-2004, 23:47    Subject: Oil Pressure Monitoring for PD Engines Quote
That's only due to software pirates.
However, there is no switch, and therefore it is likely 'just' ABS, which is the minimum standard equipment.
But that probably wouldn't have worked, because 'ASR: not for 74 and 96 kW, as standard' new_tomato.gif.
ASZ without ASR? That would be typical VW again.
as if we hadn't warned you about it icon_twisted.gif.
Buy a Skoda. ALH model with ABS/ASR/EDS/MSR, and optionally WITHOUT ESP icon_razz.gif.
CU Gremlin.
Translated on 13-09-2026, 11:58.
WarLord
Post18-02-2004, 0:00    Subject: Oil Pressure Monitoring for PD Engines Quote
@ulf
You should be happy, because, in my opinion, you can forget about ASR.
Best regards, WarLord.
Translated on 13-09-2026, 11:59.
Gremlin
Post18-02-2004, 0:03    Subject: Oil Pressure Monitoring for PD Engines Quote
Okay, so without ASR, I can't even get away from the traffic light when the road is wet... icon_twisted.gif
'Cu Gremlin'
Translated on 13-09-2026, 12:00.
Julian
Post18-02-2004, 0:44    Subject: Oil Pressure Monitoring for PD Engines Quote
While I don't want to contradict Ralf, things aren't quite that simple with my awx. In the instrument cluster, you can immediately see after starting the engine whether the oil pressure is correct and exceeds the required 2 bar. This is independent of the engine speed.
Gremlin
Post18-02-2004, 0:48    Subject: Oil Pressure Monitoring for PD Engines Quote
and the ALH (or, more precisely, the VDO instrument cluster from VW/Skoda) ignored the lack of oil pressure at idle until very recently.
I'm telling you, it's a software issue.
CU Gremlin.
Translated on 13-09-2026, 12:01.
Julian
Post18-02-2004, 0:58    Subject: Oil Pressure Monitoring for PD Engines Quote
If you start your ALH engine and there's no oil in it, would it run until it fails without any warning? Really? Did the phone technicians at Skoda/VW also consider that the driver might hear the squeaking from the pistons, etc., so that they would add oil? icon_smile.gif
Translated on 13-09-2026, 12:02.
Post18-02-2004, 7:25    Subject: Oil Pressure Monitoring for PD Engines Quote
Julian wrote:
While I don't necessarily want to contradict Ralf, things aren't quite that simple with my awx. In the instrument cluster, you can immediately see after starting the engine whether the oil pressure is correct and whether it's above the required 2 bar. This is independent of the engine speed.
Hi Julian,
Then, in your SLP, there should be more to find than just 1 oil pressureswitch?
-> Pressure source, etc.
Do you know how your system is structured?
And what car are you currently driving?
Translated on 13-09-2026, 12:03.
Julian
Post18-02-2004, 10:02    Subject: Oil Pressure Monitoring for PD Engines Quote
I need to check that out, good idea.
It's an A4 8E.
Translated on 13-09-2026, 12:04.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Jetta TD Oil Pressure: Troubleshooting & Solutions Diesel Engine Technology
No new posts Engine shuts down unexpectedly, oil pressure warning ligh... Diesel Engine Technology
No new posts Data Bus Software Status Monitoring: Error 18263 On-Board Diagnostics (OBD)
No new posts ESP VP37 Removal: AEL Engine (A6 2.5 TDI) Diesel Engine Technology
