Hello, Bubbes!
You reported that the engine started running immediately after the ESP replacement. However, the machine no longer starts after the ESP is rotated.
Have you tried reverting it to the old position? I suspect you might have adjusted the ESP in the wrong direction (probably "late").
Was the starting point marked? If so, it should be easy to restore that position.
Why did you actually adjust the pump? What was the injection start setting in the basic settings mode in VAG-COM?
I'm just mentioning, based on my own experience, that even a slight rotation of just a few tenths of a millimeter can cause a noticeable change in the injection start. If you've rotated the pump, for example, just a fraction of a millimeter in the wrong direction, that could be the cause of your starting problem.
Quote: |
| Can a diesel engine also "flood"??? |
No! "Flooding" in gasoline engines is primarily caused by a "wet" spark plug, which prevents the spark from firing.
Good luck correcting the pump timing!
Alex.
Touran 1.9 TDI, EZ 09/2004
