OBD2 for TDCi
glitch
Post18-01-2004, 20:39    Subject: OBD2 for TDCi Quote
Does anyone have experience using OBD2 with TDCI engines?
How about the prevalence (and benefits) of this technology in diesel vehicles?
Thank you for the information.
Translated on 19-07-2026, 18:45.
mersente
Post13-02-2004, 22:37    Subject: OBD2 for TDCi Quote
Hello, I can tell you that the OBD (On-Board Diagnostics) requirement for diesel vehicles with new registrations came into effect on December 1, 2005.
It is possible or likely that vehicles with diesel-specific OBD systems are already available on the market.
You can identify them by the key number 5 on the letter or certificate, where it will state: '14 for diesel engines with OBD' or '15 for diesel direct injection engines with OBD.'
For all vehicles where this is indicated, you can use the diagnostic options available through the OBD (On-Board Diagnostics) system.
If it simply says '02' for diesel or '22' for diesel direct injection, you won't be able to determine which one it is because these models are not OBD-compatible.
Translated on 19-07-2026, 18:46.
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts P1000 - OBD2 System Test Incomplete Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts OBD2 Adapter: MFA via OBD2 Diesel Engine Technology
No new posts Performance issues Focus TDCI Diesel Engine Technology
This topic is locked, you cannot edit or reply. TDCI Engine Jerking: Causes and Fixes Diesel Engine Technology
No new posts TDCI: Implausible Signals from Throttle Position Sensor Diesel Engine Technology
