Do PD Engines Have Fuel Injection Pumps?
Jonny1303
Post19-06-2002, 7:22    Subject: Do PD Engines Have Fuel Injection Pumps? Quote
Hello, fellow community members,
Please forgive me for the extremely stupid question icon_redface.gif.
The reason for my question is that I might want to install a 3-cylinder engine in a VW Beetle, and in that case, an injection pump (due to its size!) would be a reason not to do it.
Sure, here's the translation:
'Thank you in advance.'
Jürgen.
Translated on 01-11-2026, 16:00.
Stukov
Post19-06-2002, 8:02    Subject: Do PD Engines Have Fuel Injection Pumps? Quote
It is said: PD.
So, regarding the pump-nozzle system, each nozzle has its own pump element. Because of the short distance (within the component) between the pump and the nozzle, a high pressure can be generated.
Translated on 01-11-2026, 16:01.
Jonny1303
Post19-06-2002, 9:22    Subject: SEO-Optimized Website Design: Best Practices Quote
I thought so!
I guess I'll have something to tinker with for the next winter icon_wink.gif.
Now I just need to find a suitable gearbox and get the approval from the TÜV (German technical inspection agency).
Best regards.
Jürgen.
Translated on 01-11-2026, 16:02.
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts DIY solution for starting engines with VP 37 Troubleshooting & Guides
No new posts VAG Engine Specs: Dimensions & Wear Limits Technical Data
No new posts Do Brake Rotors Have a Direction? Transmission, Chassis, Body & Interior
No new posts Fuel Injection Pump: What Type Is It? Diesel Engine Technology
No new posts Want to have Diesel Engine Technology
No new posts AKU 550: What to do now? Diesel Engine Technology
