Error codes and their possible causes for Teves Mark 20 IE (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post12-06-2002, 16:01    Subject: Error codes and their possible causes for Teves Mark 20 IE Quote
00283
Speed sensor front left G47 or Speed sensor front left G47 Open/Short circuit to positive.
Rotor is dirty or damaged.
Wheel bearing play is excessive.
Speed sensor G47 not properly installed.
Speed sensor G47 is defective.
Short circuit to ground.
Incorrect ECU version.
Wiring interruption, short circuit to positive in the wiring between the speed sensor G47 and the control unit J104.
00285
Speed sensor front right G45 or Speed sensor front right G45 Open circuit/short circuit to positive voltage
Speed sensor G45 not properly installed.
Speed sensor G45 is defective.
Wiring interruption, short circuit to positive in the wiring between the speed sensor G45 and control unit J104.
00287
Rear Right Tachometer G44 or Rear Right Tachometer G44 Open Circuit/Short to Ground
Speed sensor G44 not properly installed.
Speed sensor G44 is defective.
Wiring fault, short circuit to positive in the wiring between the speed sensor G44 and the control unit J104.
00290
Rear Left Speed Sensor G46 or Rear Left Speed Sensor G46 Open/Short to Power
Speed sensor G46 not properly installed.
Speed sensor G46 is defective.
Wiring interruption, short circuit to positive in the wiring between speed sensor G46 and control unit J104.
00538
Reference Voltage
Interruption, Short circuit after plus or ground in the lines:
{INPUT_DEVICE} for {ROTATION_SPEED} G202
Sensor for Lateral Acceleration G200
Donor 1 for Brake Pressure G201
Donor 2 for Brake Pressure G214
00668
Board voltage, terminal 30, signal outside of tolerance
Interruption, Short circuit to positive or negative.
00778
Sender for Steering Angle G85: No communication, implausible signal, mechanical failure
Interruption or loose connection in the data lines between the sender for steering angle G85 and the control unit J104
Gear for steering angle -G85- defective
Sender for Steering Angle -G85- sends no or incorrect setting values
The mounting position for the sensor for steering angle G85 is incorrect.
Vehicle geometry is not optimal.
The steering wheel was removed and subsequently, no zero-tolerance adjustment was performed.
Unacceptable vibrations in the steering system due to wear and tear.
00810
Provide 1/2 for brake pressure, implausible signal
Brake pressure supply line to actuator 1 or 2 interrupted.
Short circuit the signal line to sensor 1 for brake pressure G201 or sensor 2 for brake pressure -G214
Faulty: Sender 1 for Brake Pressure G201 or Sender 2 for Brake Pressure G214
A hydraulic brake circuit has failed.
00812
Switch for magnetic field Brake Pressure - F84
Brake booster malfunction
00813
Faulty brake pressure sensor G214 in the circuit
Faulty G214 brake pressure sensor
00814
Magnet coil for brake pressure N247
Mass in the pipes:
Faulty power stage in control unit J104
ABS control unit J104 is faulty.
01044
ECU incorrectly coded
The control unit -J104 is coded for a vehicle with a manual transmission. The vehicle is equipped with an automatic transmission.
01130
ABS Operation: Implausible Signal
Electrical interference caused by external sources (high-frequency radiation)
01276
Hydraulic pump ABS V64 signal outside tolerance
Interruption, Short circuit after the plus or in the lines
Internal Connection Hydraulic Pump V64 to Control Unit
Hydraulic pump V64 faulty
01279
Gear for Longitudinal Acceleration G251 electric. Fault in the electrical circuit
The mounting position of the G251 longitudinal acceleration sensor is incorrect.
Accelerator for Longitudinal Acceleration G251 defective
01423
Sensor for Lateral Acceleration G200, electronic. Fault in the electrical circuit
Sensor for Lateral Acceleration G200 is defective
The mounting position of the G200 accelerometer sensor is not correct.
01434
Relay for brake light suppression. ESPJ508 electrical. Fault in the electrical circuit
Relay for brake light suppression J508 is defective
01435
Donor 1 for Brake Pressure G201 electric. Fault in the electrical circuit
Donor 1 for Brake Pressure G201 - Defective
01542
The mounting position of the encoder G202 is not correct.
Encoder for speed G202 defective
65535
Control unit malfunction
Engine Control Unit J104 is faulty.
Tschüss
Michael II
Ratings - Error codes and their possible causes for Teves Mark 20 IE
No new posts Teves Mark 60: Error Codes & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their possible causes for Mercedes-Benz A... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fehlercodes und deren mögliche Ursachen für MKB AAT, AEL Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts @ Michale II Teves MK 20 Diesel Engine Technology
No new posts ABS/EDS Teves MK 04 1H0907379E On-Board Diagnostics (OBD)
No new posts Technical Documentation Teves MK20 Diesel Engine Technology
No new posts Unlock code adjustments, brake control unit, ESP, Mark 60 Transmission, Chassis, Body & Interior
