Teves Mark 60: Error Codes & Troubleshooting (Solution)
Michael II
Post12-06-2002, 16:39    Subject: Teves Mark 60: Error Codes & Troubleshooting Quote
Error codes and their possible causes for Teves Mark 60.
00003
Control unit defective.
Control unit J104 is defective.
00283
Front left speed sensor (G47) or front left speed sensor (G47) - open circuit/short circuit to positive.
Rotor is dirty or damaged.
Wheel bearing play is excessive.
Speed sensor G47 not installed correctly.
Tachometer sensor G47 is defective.
Short circuit to ground.
Incorrect control unit version.
Wiring fault: Open circuit or short circuit to positive voltage in the wiring between speed sensor G47 and control unit J104.
00285
Crankshaft position sensor, front right, G45 or Crankshaft position sensor, front right, G45, open circuit/short circuit to positive.
Speed sensor G45 not installed correctly.
Tachometer sensor G45 is defective.
Wiring fault: Open circuit or short circuit to positive voltage in the wiring between speed sensor G45 and control unit J104.
00287
Rear right speed sensor G44 or rear right speed sensor G44, open circuit/short circuit to positive.
Speed sensor G44 not installed correctly.
Tachometer sensor G44 is defective.
Wiring fault: Open circuit or short circuit to positive voltage in the wiring between speed sensor G44 and control unit J104.
00290
Rear left speed sensor G46 or rear left speed sensor G46, open circuit/short circuit to positive.
Speed sensor G46 not installed correctly.
Tachometer sensor G46 is defective.
Wiring fault: Open circuit or short circuit to positive voltage in the wiring between speed sensor G46 and control unit J104.
00538
Reference voltage.
Interruption, short circuit to positive or ground in the wiring:
Encoder for rotational speed G202.
Accelerometer G200 (for lateral acceleration).
Donor 1 for brake pressure G201.
Brake pressure sensor 2, part number G214.
00668
Board voltage at terminal 30: signal out of range.
Interruption, short circuit to positive or ground.
00778
No communication from steering angle sensor G85, implausible signal, mechanical fault.
Interruption or loose connection in the data lines between the steering angle sensor (G85) and the control unit (J104).
Steering angle sensor - G85 - defective.
The steering angle sensor (G85) is not sending any data or is transmitting incorrect values.
The installation position of the steering angle sensor (G85) is incorrect.
The alignment is incorrect.
The steering wheel was removed and subsequently, no zeroing/calibration procedure was performed.
Unauthorized vibrations in the steering due to wear.
00810
Brake pressure sensor 1/2: Implausible signal.
Mass connection to brake pressure sensor 1 or 2 is interrupted.
Short circuit in the signal line to sensor 1 for brake pressure (G201) or sensor 2 for brake pressure (-G214).
Sensor 1 for brake pressure (G201) or sensor 2 for brake pressure (G214) is defective.
A hydraulic brake circuit has failed.
00812
Löseschalter f. Magnetsp. f. Brake pressure - F84.
Interruption, short circuit to positive or ground in the wiring.
Brake booster malfunction.
00813
Donor 2 for brake pressure G214 - electrical fault in the circuit.
Donor 2 for brake pressure, part number G214, is defective.
00814
Magnetic coil for brake pressure - N247.
Interruption, short circuit to positive.
Mass buildup in the lines.
Power amplifier in control unit J104 is defective.
ABS control unit J104 defective.
01044
Control unit incorrectly programmed.
The control unit (J104) is programmed for a vehicle with a manual transmission, but the vehicle is equipped with an automatic transmission.
01130
ABS operation: implausible signal.
Electrical disturbances caused by external interference sources (high-frequency radiation).
01276
Hydraulic pump ABS V64: signal out of range.
Interruption, short circuit to positive or in the wiring.
Internal connection from the hydraulic pump (V64) to the control unit.
Hydraulic pump V64 is defective.
01279
G251 longitudinal acceleration sensor - electrical fault in the circuit.
The installation orientation of the longitudinal acceleration sensor G251 is incorrect.
Defective sensor for longitudinal acceleration G251.
01423
Lateral acceleration sensor G200: electrical fault in the circuit.
Lateral acceleration sensor G200 is defective.
The installation orientation of the G200 lateral acceleration sensor is incorrect.
01434
Relay for brake light suppression, ESPJ508, electrical fault in the circuit.
Brake light suppression relay J508 is defective.
01435
Donor 1 for brake pressure, error code G201: electrical fault in the circuit.
Donor 1 for brake pressure - defective.
01486
The ESP driving test has been activated, see https://community.dieselschrauber.org/en/viewtopic.php?t=26751.
01487
ESP driving test timeout.
01542
Encoder for rotary axis G202: implausible signal.
The installation orientation of the angular rate sensor (G202) is incorrect.
Encoder for axis G202 is defective.
65535
Tschüss
Michael II
Translated on 30-07-2026, 1:58.
Ratings - Teves Mark 60: Error Codes & Troubleshooting
No new posts Error codes and their possible causes for Teves Mark 20 IE Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their possible causes for Mercedes-Benz A... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fehlercodes und deren mögliche Ursachen für MKB AAT, AEL Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Teves MK 20: Michael II Replacement Diesel Engine Technology
No new posts ABS/EDS Teves MK 04 - 1H0907379E On-Board Diagnostics (OBD)
No new posts Technical Documentation Teves MK20 Diesel Engine Technology
No new posts Unlock code adjustments, brake control unit, ESP, Mark 60 Transmission, Chassis, Body & Interior
