http://www.cheesebuerger.de/smilies/schilder/10.gif For example, according to a tire calculator, the following results are obtained:
/viewtopic.php?t=673&highlight=tire calculator and...
http://home.t-online.de/home/bitspark/156/reifendaten.htm
If you enter your data there, the deviation will be displayed directly (in your case, 7%).
Besides the speedometer deviation, the engine also runs at 7% higher RPM (at the same speed).
Increased fuel consumption.
I don't care if the tires are labeled as 205/50 or not...
Risky move, but it's your decision. Just a tip: In case of an accident or insurance claim, the tire dimensions are one of the first things that an officer or expert will note. Also, during a routine vehicle inspection, my tire dimensions were checked once. I hope you are aware of the seriousness of such an offense!
Private.
