The "ticking" sound from the engine is gone now...
Wesso
Post14-06-2002, 21:32    Subject: The "ticking" sound from the engine is gone now... Quote
Hello everyone,
Here, some time ago, we discussed the topic of:
'A ticking or tapping sound is coming from the engine compartment.'
Some suspected valves, or simply resonances, like...
Me too...
It was the same for me.
I didn't have the underbody protection installed on my car at that time.
At that time, I could also hear a distinct tapping sound (whatever it was).
listen.
Since I reinstalled my underbody insulation...
It's gone once it's in.
Fazi: In my case, it was resonances coming from the trouser leg, or...
Transition pieces.
Best regards.
sw
Jan6K
Avatar-Jan6K
Post14-06-2002, 22:02    Subject: The "ticking" sound from the engine is gone now... Quote
Interesting observation! It at least confirms the assumptions from back then.
I have all the soundproofing materials in place, so nothing was removed, and I'm still experiencing these noises. However, I suspect the noises are probably highly dependent on the specific construction of the car, and there are definitely differences between them.
Furthermore, the noise is temperature-dependent; it's more noticeable when it's warm, which also aligns with the combustion noise theory, as temperature is a parameter that affects the injection timing.
Perhaps I should check to see if all the insulation parts are properly installed; you never know with my "expert" workshop.
Jan.
1Z5 CFHF / AHB H4D
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DZR now with option for "VAGCOM Stopwatch" Diesel Engine Technology
No new posts "Engine running via K-line," VCDS On-Board Diagnostics (OBD)
No new posts AVF Engine: Analyzing "Rough Idle" Log File (Part 2) Upload
No new posts New LOG file for "Erratic Idle AVF Motor" Upload
