Jan6K
11-06-2002, 9:21 Subject: To the caravan enthusiasts: A mirror |
Hello everyone,
especially those driving around the area in cars belonging to Dutch condominiums  .
Gibt es fuer die Ibiza-Spiegel (sind IMO baugleich zum Golf 4 und zum neuen Passat) solche aufsteckbaren Verlaengerungen als Zusatzspiegel? If so, where?
I'm actually looking for something like that because I find it much more gentle on the car than the parts you attach to the fenders. And since the trailer is quite narrow at 2 meters wide, it should be sufficient from a visibility point of view (with my Passat, it even works with the trailer without using mirrors in some cases, but the Ibiza is narrower).
Jan. 1Z5 CFHF  / AHB H4D
Translated on 15-07-2026, 7:56.
wolle Blaumann
13-06-2002, 6:15 Subject: To the caravan enthusiasts: A mirror |
Hi Jan,
I'll check with an acquaintance. I will post a new answer to you later today. This is just so you know that something is happening.
Wool
Translated on 15-07-2026, 7:58.
Jan6K
13-06-2002, 7:03 Subject: To the caravan enthusiasts: A mirror |
Thank you, that's very kind of you!
eagerly anticipating
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
13-06-2002, 9:21 Subject: To the caravan enthusiasts: A mirror |
Hello Jan,
Atu sells clip-on mirrors where a type of screw clamp is attached between the mirror housing (plastic at the top) and the mirror glass. These work quite well in my A3.
However, there must be a gap of at least 3 mm between the mirror glass and the frame, and the surface of the frame should not be too curved, otherwise it may break when clamped.
The price must have been around 70 DM about 4-5 years ago, but I don't remember exactly.
Translated on 15-07-2026, 7:59.
Profile PM WWW Garage |
Jan6K
13-06-2002, 13:00 Subject: To the caravan enthusiasts: A mirror |
Hello Rainer,
"That also sounds very useful; I'll check with ATU about it. Will this damage the painted mirror housings over time, or will it quickly cause scratches?"
Translated on 15-07-2026, 8:00.
13-06-2002, 14:08 Subject: To the caravan enthusiasts: A mirror |
The "screw terminals" are rubberized, and so far I haven't been able to detect any scratches.
I've probably attached and detached those things at least 50 times.
Translated on 15-07-2026, 8:01.
wolle Blaumann
13-06-2002, 21:15 Subject: To the caravan enthusiasts: A mirror |
Hi Jan,
You want to do someone a favor, and then this happens. My acquaintance wasn't here today...  I was able to reach him at home. Tomorrow he will be back at work. Then he can tell me the exact price and the delivery status.
I'm really sorry that I couldn't provide you with the information you requested today. Please accept my apologies...
But I will keep my promise!!!!!!!!!!!!!!!!!!!
(so und jetzt sind auch noch meine Ausrufungszeichen alle....  )
Okay, see you then, and have a good evening.
Wool
Translated on 15-07-2026, 8:02.
wolle Blaumann
14-06-2002, 10:32 Subject: To the caravan enthusiasts: A mirror |
Hi Jan,
I just received the information. So... for example, there's an exterior mirror that is attached to the original mirror using clips. It's also supposed to be rubberized. The manufacturer is called Hagus. I also have the part number on hand, just in case.
Nun das wichtigste.... das Teil kostet 34,20 € incl. Fairy tale tax.
Well... if you're interested, just keep in mind that shipping costs will be added.
I hope this has been at least a little helpful to you.
Wool
Translated on 15-07-2026, 8:04.
Jan6K
14-06-2002, 15:38 Subject: To the caravan enthusiasts: A mirror |
Thank you very much!
I'll check with ATU about this. However, you can still send me the part number via email; it might be the same mirror after all. My email address is jan AT richling DOT de (written like this to avoid spam).
Translated on 15-07-2026, 8:05.
