External Tooth Screw: Buy Now!
boernhard
Post15-03-2004, 13:06    Subject: External Tooth Screw: Buy Now! Quote
Hello everyone,
I'm in the process of removing a turbocharger from a VW T4 1.9L TD (non-TDI). The turbocharger is secured with 4 very unusual screws; they look like an external splined drive with a diameter of approximately 14-15 mm. The heads of the screws have 5 holes arranged in a pattern like a cube. Can anyone tell me what kind of tool I need to use for these, and perhaps where I can find one?
Thank you, Bernhard.
Translated on 07-09-2026, 19:34.
Mc_Givertechnik
2010 Volkswagen T5
Post15-03-2004, 13:38    Subject: External Tooth Screw: Buy Now! Quote
Hello.
Measure the diameter and count the teeth. Then, you'll definitely find the right tool at a well-stocked hardware store.
Regards, Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 07-09-2026, 19:35.
haehnlein
Post15-03-2004, 14:15    Subject: External Tooth Screw: Buy Now! Quote
I don't know exactly how it looks for you, but a standard double-ended hexagonal wrench (size 15 icon_confused.gif) should be sufficient.
____________
Kein Auto mehr!
boernhard
Post16-03-2004, 11:28    Subject: Problem solved: [Solution/Guide/Tips]:-) Quote
Thanks, Christian, that was exactly the solution. A 12-point socket fit.
That's how forums are fun icon_biggrin.gif.
Björn.
Translated on 07-09-2026, 19:36.
No new posts A3 8L Screw Corrosion: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts KW Coilover Screw: Buy Now! Diesel Engine Technology
No new posts AFN und die berüchtigte Kw-Schraube Diesel Engine Technology
No new posts VA Screw in Manifold: How to Remove? Diesel Engine Technology
No new posts Screw broken off in the turbocharger Diesel Engine Technology
