agr new problem
tino
Post22-04-2002, 15:13    Subject: agr new problem Quote
hello
I also disconnected my EGR valve, but initially only the connector. After the ASU (vehicle inspection), I removed the hose and installed a blind plug. At first, everything was fine, but after a minute, I had the same problem as the PD-TDI engines – it felt like it was stuck, and the engine barely revved. So, I reassembled everything, then disconnected the connector again, but there was still a minimal amount of exhaust gas recirculation. How is that possible? Shouldn't the exhaust gases no longer be entering? And how can I disconnect the EGR valve differently?
I drive a Skoda with a TDI 110 PS (horsepower) engine, model AHF.
'Thank you.'
Best regards.
tino
Michael II
Post22-04-2002, 15:35    Subject: Re: agr Quote
If you just unplug the connector like that, you'll get an error message in your control unit. Since the engine control unit takes the exhaust flow from the EGR system into account during air mass calculation, it is possible that, due to the error entry, pre-set values are being used in this calculation.
This would explain the sluggish behavior of the engine.
Bye.
Michael II.
No new posts VTG problem Diesel Engine Technology
No new posts Zentralverriegelungs problem Transmission, Chassis, Body & Interior
No new posts problem mit dem Tempomat On-Board Diagnostics (OBD)
No new posts V6 TDI fuel injection pump problem Diesel Engine Technology
