benmen wrote: |
| I am still interested to know whether the voltage from the MSW |
does not match the voltage from the RSW
Quote: |
in series pumps.
Hi Benjamin,
"As far as I know, the effective voltage at the MSW is not published anywhere. At what values do you want to determine a (dis)agreement?"
Is there actually a lookup table for converting inductance to volts??? Or how is the voltage value generated in measurement block 001 for RSW?}
By comparing the inductances of the reference and measurement coils using a 10 kHz signal, and somehow incorporating this ratio into the specified voltage.
A smaller inductance of the measuring coil results in a lower voltage, and vice versa.
Sorry, but I don't know any more details than that.
