Fix Error Codes: Troubleshooting ECU Issues
Go to page: 1, 2, 3  Next
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Ste.Bo
Karma: +89 / -0   Thank you, like it!
Post10-02-2025, 19:48    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
Hello everyone,
"This weekend, I replaced the battery in my parents' Passat B8 (2016), and afterwards, I got a bunch of error messages for things like the audio system (AAC), parking sensors (PDC), hill start assist, ABS, and lane keeping assist."
There were consistent voltage drops, communication errors, and a lack of proper calibration. Not a single defect was found.
I was unable to clear the errors, either through the batch service (nothing happened) or by opening each control unit individually. In the latter case, at least I received the error message: "The request to delete fault codes was not accepted by the control unit."
Unfortunately, I was in a hurry and didn't save the car scan data, nor did I take any screenshots of the error messages.
I then used the KTS 980 device from the company to prepare the two items for their journey home.
Kennt das jemand? Was habe ich übersehen? Step error?
Translated on 23-07-2026, 22:21.
Karma: +643 / -0   Thank you, like it!
dieselschrauber and Ste.Bo likes this.
Post10-02-2025, 20:11    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
Was the new battery properly installed and configured?
Translated on 23-07-2026, 22:22.
Ste.Bo
Post10-02-2025, 20:40    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
Rüdi wrote:
Was the new battery calibrated/programmed?
Yes, successful! All values have been recorded.
I could also clear all the errors in the gateway (diagnostics) and engine control unit afterwards. However, I can't do that for the rest of the system.
Translated on 23-07-2026, 22:23.
Ste.Bo likes this.
Post11-02-2025, 11:10    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
In such cases, it can be helpful to turn off the ignition, drink some coffee, start a new diagnostic session, and perform another bulk deletion.
Possibly, there was a software-related issue that caused a blockage at the diagnostic gateway. icon_idea.gif
Translated on 23-07-2026, 22:24.
Ste.Bo
Post11-02-2025, 14:36    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
Okay, dear community,
My father couldn't start the engine this morning. I sent someone over who used a generic tool to read the car's diagnostics. I won't be able to get there myself until Friday.
The following error messages are occurring:
Engine:
1) U112300 - CAN communication; fault/defect - Permanent.
Brake:
1) C114602 - Tire Pressure Monitoring System (TPMS), CAN signal error - Permanent.
Restraints:
1) U112300 - Frame CAN bus failure - Permanent.
ADAS:
1) U112200 - CAN bus; implausible message - Permanent.
2) U112300 - Frame CAN bus failure - Permanent.
He doesn't even get into the TPMS system.
What did I fry up while changing the battery?
Translated on 23-07-2026, 22:25.
Ste.Bo
dieselschrauber likes this.
Post11-02-2025, 20:01    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
I noticed in the wiring diagrams that all the mentioned control units are connected to the same fuse (SB32), except for the TPMS, which is connected to fuse (SB7).
I told my father to check the fuses with a multimeter. Both are good and receiving power. I guess I'll probably have to postpone it until the weekend.
Translated on 23-07-2026, 22:27.
Ste.Bo
Post15-02-2025, 17:11    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
Okay, for everyone who's bored on the weekend.
I was working on a car today. There are a huge number of errors in the car's diagnostic scan (attached). Some control units still won't allow me to clear the errors, and with others, the error reappears immediately.
Vehicle cannot be started!
The ADAC (German Automobile Club) was there temporarily and said that the "component protection" feature might have been triggered. They stated that without assistance from Volkswagen's customer service, nothing could be done.
Maybe someone has recommendations for other things I could watch?
Before the battery replacement, the car only had an occasional low oil pressure warning from the DSG (dual-clutch transmission), but it was still drivable. Everything else is new.
How do I start the car?
Log-OPA GTE2-WVWZZZ3CZHEXYZXYZ-236452km.txt
 File name:  Log-OPA GTE2-WVWZZZ3CZHEXYZXYZ-236452km.txt
 File size:  44.67 KB
 Downloaded:  232 times
Translated on 23-07-2026, 22:28.
Ste.Bo
Post15-02-2025, 17:36    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
Okay, one more thing. I've checked ALL the fuses in both SB and SC. They're all fine!
Translated on 23-07-2026, 22:30.
Post15-02-2025, 18:14    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
Hi Bo,
Are the battery terminals securely fastened to the battery itself, or are they loose and rattling around (causing voltage drops)?
I consider component protection to be unlikely; there are other error messages for that.
Do you have an oscilloscope that you can use to directly connect to the power supply of the control units (fuse!)?
Without any damage to the wiring harness or water ingress, this appears to be caused by significant issues within the vehicle's electrical system or the CAN bus drive.
Translated on 23-07-2026, 22:31.
Ste.Bo
Post15-02-2025, 18:37    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
At my parents' place, I only have a USB oscilloscope, which is always in the electronics kit in the car.
Okay, I'll start with the two devices that aren't responding anymore.
First, I need to secure them. We don't want them to break and disable the bus. Then, I'll check the connectors.
Thank you in advance. The information about component protection is already helpful because I'm not familiar with that and would have given up otherwise.
I'll get back to you when I know more. Probably tomorrow.
Translated on 23-07-2026, 22:32.
Ste.Bo
Post15-02-2025, 20:03    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
Does anyone know where the 120-ohm termination resistor for the comfort control units in the rear is located?
Translated on 23-07-2026, 22:33.
Karma: +1333 / -0   Thank you, like it!
Post15-02-2025, 20:20    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
Another question - what interface are you using?
Ste.Bo
Post15-02-2025, 20:36    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
Herbert wrote:
Another question - which interface are you using?
HEX-V2
Translated on 23-07-2026, 22:34.
Post15-02-2025, 22:16    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
Hi Bo.
As I interpret the Autoscan results, the problem seems to be in the CAN drive system, doesn't it?
Is the CAN comfort system completely separate from the CAN drive system?
It is only in the gateway control unit that the CAN drive, CAN diagnostics, and CAN comfort functions are integrated.
Translated on 23-07-2026, 22:35.
Ste.Bo
Post15-02-2025, 23:16    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
dieselschrauber wrote:
Hi Bo.
As I interpret the Autoscan, the problem seems to be in the CAN drive, or not?
https://www.canhack.de/viewtopic.php?t=2351#6520
Best regards, Rainer
You've just made me pause for a moment.
My reasoning was as follows:
- ABS, parking assist, and ESP usually function normally after disconnecting the battery if the sensors have not yet been initialized (I tested by disconnecting the negative terminal last night).
- The ACC (Adaptive Cruise Control), lane change assist, and tire pressure monitoring system are all connected to the extended module, and they're all malfunctioning.
On the other hand, the parking assist system is not responding, but when I disconnect the connector, nothing changes.
I need to sleep on it.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Translated on 26-07-2026, 17:34.
Post15-02-2025, 23:22    Subject: Fix Error Codes: Troubleshooting ECU Issues Quote
"The engine, transmission, adaptive cruise control, ESP, etc., are all controlled by the CAN bus system, which is where the control units with errors are showing up in your car scan."
Am I missing something?
Battery possibly connected with reversed polarity, and some control units may be malfunctioning.
Translated on 26-07-2026, 17:36.
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Kann Fehler im Boardnetz nicht löschen On-Board Diagnostics (OBD)
No new posts Kombiinstrument (Kann Fehler nicht löschen) Diesel Engine Technology
No new posts Can't find any errors! AJM - Whose microphone is malfunct... On-Board Diagnostics (OBD)
No new posts ECU Errors: Common Issues and Troubleshooting On-Board Diagnostics (OBD)
