Golf 4 Speaker Installation Guide
VM2Golf4
Post24-04-2004, 8:16    Subject: Golf 4 Speaker Installation Guide Quote
I have a problem.
I want to remove the front speakers (in the doors) from my Golf 4, but they are not removable, and I can't see any screws or anything like that.
Are they glued on, or do I have to remove the entire door panel to get to them?
Thank you in advance for your reply.
wolfgang
Translated on 07-10-2026, 23:05.
nick_muc
Post24-04-2004, 12:57    Subject: Golf 4 Speaker Installation Guide Quote
Normally, they are fastened with rivets (plastic). You can simply drill them out and remove them. When installing new ones, you can use simple metal screws, or even Spax screws if necessary.
Translated on 07-10-2026, 23:06.
Post24-04-2004, 13:12    Subject: Golf 4: Speaker Installation Guide Quote
VM2Golf4 wrote:
are they glued on, or do I have to remove the entire door panel to get to them?
They are screwed or riveted to the door frame (I've seen both). You can only access them if you remove the entire door panel.
These are not standard speakers. The speakers are recessed into a plastic housing. If you want to install different standard speakers, you will need a suitable adapter ring.
Dan.jel
Post26-04-2004, 10:21    Subject: Golf 4 Speaker Installation Guide Quote
Would you like to install different speakers and need some recommendations?
In the Golf 4, I personally like the Hertz HSK 165 very much. The Peerless Definition 6 or various Exakt! models are also at least just as suitable! Of course, it's best to listen to them yourself! Frank Miketta in Celle (www.carhifistore.de) is a very good dealer, but where are you actually from? icon_biggrin.gif
By the way, there aren't only adapter rings made of plastic, but also those made of metal.
The more securely a speaker is mounted, the more powerful and dynamic it can sound.
You should also use some damping panels to reduce the resonance of the doors, which will minimize the rattling and booming sounds.
My mid-bass drivers are mounted on steel rings, which are then bonded to the plastic adapter rings and the door using filler.
A tighter fit would only be possible by using red brass rings or by welding. icon_twisted.gif
Daniel.
Translated on 07-10-2026, 23:08.
Julian
Post26-04-2004, 11:49    Subject: Golf 4 Speaker Installation Guide Quote
The boxes are ALWAYS factory-riveted. Drill out the rivets, but be careful not to let any rivet pieces fall into the door frame, otherwise it will be noisy... icon_wink.gif
Retrofit kits have a mounting frame that is first riveted to the car body, and then the box itself is screwed onto the frame.
Translated on 07-10-2026, 23:10.
Dan.jel
Post26-04-2004, 11:55    Subject: Golf 4 Speaker Installation Guide Quote
Boxing?
Most of the aftermarket speakers are not recommended at all; I might as well just put a portable radio on the seat.
haehnlein
Post26-04-2004, 12:30    Subject: Golf 4 Speaker Installation Guide Quote
I have the Canton CS 2.16 speakers in my car (plus a subwoofer instead of the spare tire icon_mad.gif). The sound quality of the Cantons is amazing icon_exclaim.gif, and I highly recommend them.
____________
Kein Auto mehr!
Translated on 07-10-2026, 23:11.
Julian
Post26-04-2004, 17:29    Subject: Golf 4 Speaker Installation Guide Quote
I had the mbquart 218.03qx, they were awesome.....if they are still available => BUY them! icon_wink.gif
The crossover was excellent, and it provided a very clean separation of frequencies.
Translated on 07-10-2026, 23:12.
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Golf VI speaker crossover - Where is it located? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 35i: How to Replace Car Speakers Transmission, Chassis, Body & Interior
No new posts Radio installation T6, Rear speaker retrofit for van Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf TDI Manual: Specs, Review & More Diesel Engine Technology
