Golf 3 TDI Tuning: Performance & Mods
Pred
Post23-06-2004, 11:25    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
Hi everyone!
My Golf 3 TDI (MK 1Z) has a registered power output of 115 hp (but measured 125 hp on a dynamometer according to a previous inspection), achieved through modified turbocharger boost and engine control unit tuning by Wendland Motorsport.
Are there any other ways to increase performance? Different lubricants or anything else? I've also heard about other injectors. Would that be a possibility?
However, it shouldn't be anything that significantly reduces the engine's lifespan.
Sure, no problem.
Pred
Translated on 28-10-2026, 19:38.
Post23-06-2004, 11:47    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
If your 1Z really has 125 horsepower, I wouldn't do anything else, other than hope it lasts.
That's a good 38% increase in performance.
If you don't have a garage full of engines and transmissions, then just leave it alone.
Translated on 28-10-2026, 19:39.
joergs
Post23-06-2004, 12:30    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
What else do you plan to do to the 1Z?
I would rather leave it as it is. Getting more power would be too risky due to wear and tear, etc., as it would likely overheat. I completely agree with everything my predecessor said!
Post23-06-2004, 12:55    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
Pred wrote:
Are there any other ways to increase the performance?
These are likely two statements that definitely contradict each other.
Every modification made to enhance performance shortens the lifespan of an engine (to varying degrees).
In my opinion, for the 1Z engine, anything above 120 horsepower is "significantly life-shortening" icon_wink.gif.
Translated on 28-10-2026, 19:40.
Pred
Post23-06-2004, 17:58    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
Why me? That was the previous owner.
And I don't think Wendland is doing anything shady. They're not just any company; they're one of the most, if not *the* most, reputable tuners (specifically for diesel engines).
But then I'll just let it go, if anything else would stress him out too much...
Thank you for the quick responses.
Pred
Translated on 28-10-2026, 19:42.
joergs
Post23-06-2004, 18:33    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
No one said that the tuner did anything wrong. The tuner simply does what the customer asks of them. If the customer wants unreasonable horsepower figures and it's feasible, then the customer will certainly get it, because they're threatening to pay.
or should this now be/become icon_question.gif hidden advertising?
Pred
Post24-06-2004, 13:02    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
Yes, of course, they pay me money for me to advertise for them! icon_cool.gif
Okay, seriously, this shouldn't be seen as either an advertisement or an endorsement of Wendland. I don't even know them personally. However, they already state on their website that the engines can have approximately 120 horsepower after the tuning. And since there are also 'natural' fluctuations in performance there, 125 horsepower is basically within the range, or not far from what Wendland claims. Therefore, I assume the customer didn't insist on having a super-tuned car, regardless of how long it runs!
Pred.
Translated on 28-10-2026, 19:43.
wolfi_b
Post24-06-2004, 13:42    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
Yes, but the test benches also have a certain measurement tolerance.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 28-10-2026, 19:44.
Wombats_Friend
Post24-06-2004, 16:29    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
The only thing you can do is install larger injectors, either from an AFN engine or even a size larger. However, you'll need to have the engine control unit (ECU) re-tuned because the car will produce excessive smoke. With the AFN injectors, you might get around 140 horsepower, and with the injectors from the 150 horsepower T4, you could potentially reach a solid 150 horsepower. The question is, of course, how long will it all last. My 1Z engine also has 120 horsepower, and I'm probably going to install the AFN injectors because chip tuning with the installation of larger injectors is gentler on the engine than just chip tuning (assuming the same power output). Check here; you'll find everything your heart desires http://shop.dieselschrauber.de/index.php/cPath/35.
Translated on 28-10-2026, 19:45.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post24-06-2004, 20:58    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
If you can wait just under two weeks.
I am selling my AFN injectors with an approximate mileage of 85,000 km. icon_biggrin.gif These will be replaced by the 216 injectors from a T4. icon_cool.gif I will also have the injectors tested and checked before selling them. But I think they are still good; the engine has approximately 160 hp and no black smoke. }
B.Eng (FH) u. KFZ Meister
Translated on 28-10-2026, 19:46.
Wombats_Friend
Post24-06-2004, 22:06    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
I'm also interested! How much are you asking for it?
Translated on 28-10-2026, 19:47.
WarLord
Post24-06-2004, 22:23    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
The only thing you can do is install larger injectors from an AFN engine, or even a size larger than that.
However, you should also increase the boost pressure. But be aware that the turbocharger will already be running very close to its maximum performance, and there's no room for error.
Best regards, WarLord.
Translated on 28-10-2026, 19:48.
Rudi
Post25-06-2004, 8:17    Subject: Golf 3 TDI Tuning: Performance & Mods Quote
And if you don't want to be seen as a blight on the local landscape...
If you want to start writing for a journal, you should begin by submitting articles.
Best regards, Rudi.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Doku: Clicking Noises (Up to KW 16/98) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Opel Tuning: Performance Parts & Upgrades Transmission, Chassis, Body & Interior
No new posts Fuel Saving Tuning: Improve MPG Now! Diesel Engine Technology
No new posts Alpin Tuning Box: Performance Upgrade Diesel Engine Technology
No new posts 10cent tuning? Diesel Engine Technology
