AUS Engine: Delayed Throttle Response
voss
Post19-05-2004, 19:02    Subject: AUS Engine: Delayed Throttle Response Quote
Hello.
I'm having a problem with a Golf IV with an AUS engine:
After giving it icon_mad.gif gas, you wait 0.5-1 seconds for the engine to react, and then, in my opinion, it increases its RPM a bit too slowly. So, based on my feeling, you're probably traveling at around 40-50 horsepower ('icon_mad.gif').
Otherwise, it runs fine, with an A1 rating and a top speed of up to 210 km/h according to the speedometer. The idle is also perfect, very stable and smooth.
Error memory is clear, throttle body is clean and not sticking.
When you increase the speed while it's stationary, the throttle valve opens relatively slowly, but without sticking.
I've also heard that this issue occurs more frequently with the 1.6 16V engine, and that the dealership often replaces the engine control unit (ECU).
Can someone confirm this?
"If so, which ECUs were faulty, and what is the replacement? Perhaps someone has the corresponding part numbers."
What is the goodwill/discount offered for a vehicle manufactured in 2001?
I am grateful for any help.
Voss.
Translated on 02-10-2026, 9:32.
WarLord
Post19-05-2004, 20:35    Subject: AUS Engine: Delayed Throttle Response Quote
Okay, so the 1.6 16V isn't the quickest when it comes to responsiveness. We had two Golf IVs at work with this engine, and both exhibited this phenomenon. However, both of them ran quite well. But, I consider this engine to be a complete design flaw. It's unreliable, makes terrible noises, and consumes fuel in a perverse way.
Best regards, WarLord.
Translated on 02-10-2026, 9:34.
Manuel Thomas
Post19-05-2004, 23:38    Subject: AUS Engine: Delayed Throttle Response Quote
Have you checked the ignition timing?
Today, I had a problem with the ABS (Anti-lock Braking System), and the engine performance was low after a timing belt replacement. I adjusted the ignition timing, and suddenly the 90 horsepower was back! It was responsive and revved freely.
Manuel.
Translated on 02-10-2026, 9:35.
voss
Post21-05-2004, 18:44    Subject: AUS Engine: Delayed Throttle Response Quote
Hello.
Thank you for your interest.
I know that the 1.6 isn't the fastest, but it also has very poor responsiveness compared to another 1.6 (that my friend has). However, it's about 10 km/h faster in terms of top speed.
I also carefully checked the camshaft timing, and it was okay.
And the fact that it still takes around 0.5 seconds for the engine to rev up, even when stationary, can't be normal.
voss
Translated on 02-10-2026, 9:36.
Julian
Post21-05-2004, 19:32    Subject: AUS Engine: Delayed Throttle Response Quote
I'm not sure if the engine still has a cable connected to the accelerator pedal. If it does, please adjust it.
If Egas: Please check the plausibility to ensure it's running at 100% when at full throttle, and not just 90% or something like that...
Translated on 02-10-2026, 9:37.
voss
Post21-05-2004, 19:40    Subject: AUS Engine: Delayed Throttle Response Quote
Hello Julian,
He has an electronic throttle.
Please check to make sure it's running at 100% when at full throttle, and not just 90% or something like that.
How can I check this? Could you perhaps tell me which measurement block it's displayed in?
So far, I haven't found this information.
voss
Translated on 02-10-2026, 9:38.
Julian
Post21-05-2004, 20:50    Subject: AUS Engine: Delayed Throttle Response Quote
I don't know the exact values by heart. Just read the measurement values one by one. Is there a percentage display? If there's no gas, it should show 0%, and if it's full throttle, it should show 100%.
voss
Post22-05-2004, 11:01    Subject: AUS Engine: Delayed Throttle Response Quote
Hello Julian,
I thought the same thing, and I couldn't find anything.
Do you have the ability to check this? That would be helpful to me.
Could someone possibly check if there's a repair instruction (or something like that) available from VW?
gives?
voss
Translated on 02-10-2026, 9:39.
No new posts div. Golf 1J TDI and Gasoline, gradual loss of power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Delayed Gas Acceptance Diesel Engine Technology
No new posts EDC response to short feeder interruption On-Board Diagnostics (OBD)
No new posts Injection Timing AEL: No Response to Fuel Temp. Diesel Engine Technology
No new posts WFS cannot be programmed, no response from STG. On-Board Diagnostics (OBD)
