Golfmann Guest
05-04-2004, 20:28 Subject: Emergency mode after disconnecting EGR valve on a 2.0 DTI Opel |
Hello everyone.
I disconnected the AGR valve from a friend's car, and now the engine goes into limp mode after 5 seconds of idling, and an error message appears on the dashboard.
The engine is a 2.0 DTI from Opel. I disconnected and sealed the vacuum hose. The problem disappears under load. The error occurs when starting because there is no power.
What's the reason for that? I did the same thing with my Golf. Does the Opel ECU check the AGR valve?
Translated on 21-07-2026, 20:13.
Julian Guest
05-04-2004, 20:37 Subject: Emergency mode after disconnecting EGR valve on a 2.0 DTI Opel |
What is the manufacturing year of the Opel? It's possible that the issue lies with the OBD2 function in the engine control unit (ECU), which monitors the mass airflow sensor (MAF). If the EGR valve is faulty, it might cause the system to measure more air than usual and declare a defect.
Translated on 21-07-2026, 20:14.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
05-04-2004, 20:39 Subject: Emergency mode after disconnecting EGR valve on a 2.0 DTI Opel |
The EGR rate is usually regulated. It depends on the control unit as to what happens if it cannot be regulated.
But who says that exhaust gases *must* be sucked in?
Profile PM WWW Garage |
