christians Profi-Schrauber
13-12-2003, 23:31 Subject: Audi 100 C4: Water in A-Pillar - Fix It! |
"Water is leaking into my Audi 100 C4 from the A-pillar, specifically from a foam plug through which the cables to the driver's door pass. Of course, that plug can't be sealed properly. The question is, where does water most commonly enter the A-pillar on this model? The car does NOT have a sunroof or anything similar."
Christian. Gruß Christian
Translated on 24-09-2026, 6:49.
mersente Guest
13-02-2004, 23:48 Subject: Audi 100 C4: Water in A-Pillar - Fix It! |
How about the coolant reservoir (located under the windshield, behind the engine)?
Are all the processes free?
Translated on 24-09-2026, 6:50.
14-02-2004, 2:36 Subject: Audi 100 C4: Water in A-Pillar - Fix It! |
Yes, if they are on, it's coming from the heating system.
I might have found the cause, but I need to observe it further to be sure.
A seal on a weld seam in the water reservoir, located between the fuse/relay box and the support bracket, had ruptured. I have resealed it and am waiting to see if the problem is resolved. Gruß Christian
mersente Guest
14-02-2004, 21:58 Subject: Audi 100 C4: Water in A-Pillar - Fix It! |
Yes, I'm curious to see what happens.
Translated on 24-09-2026, 6:51.
13-04-2004, 12:57 Subject: Audi 100 C4: Water in A-Pillar - Fix It! |
The error has not occurred again. I wasn't entirely sure at first, but it seems there might have been some residual water leaking out. Gruß Christian
mersente Guest
13-04-2004, 22:00 Subject: Audi 100 C4: Water in A-Pillar - Fix It! |
Great, so you've finally found it.
