wacken Guest
07-04-2004, 0:55 Subject: Engine Failure: Causes and Solutions |
Hello, my new A3 2.0 TDI occasionally has a brief hesitation, which is hard to describe and extremely rare. I've driven about 950 km and experienced it maybe 2-3 times, so it's not frequent. It usually happens at low speeds, when starting or in city traffic. It's only for a fraction of a second, just a very short moment, as if it briefly loses power. The strange thing is that my previous 2.0 TDI also had this occasionally. And as far as I can remember, my A4 1.9 TDI (130 hp) even had it too? What is this?
Translated on 12-10-2026, 21:53.
Julian Guest
07-04-2004, 4:58 Subject: Engine Failure: Causes and Solutions |
Do you still have the box on, or not? If so, try it without it first... What's the result?
Translated on 12-10-2026, 21:54.
wacken Guest
07-04-2004, 14:15 Subject: Engine Failure: Causes and Solutions |
That has absolutely nothing to do with boxing.
Steffarn Profi-Schrauber
07-04-2004, 19:12 Subject: Engine Failure: Causes and Solutions |
I would just leave it as it is for now.
Perhaps you might also make a driving mistake that you don't even notice.
e.g., to approach from below.
 B.Eng (FH) u. KFZ Meister
Profile PM Email Garage |
wacken Guest
07-04-2004, 19:19 Subject: Engine Failure: Causes and Solutions |
I'm not sure if the engine was under-revving, as I haven't driven it much before. But if that's the case, the engine shouldn't be misfiring, right? And I can rule out driver error; that wasn't the problem.
Translated on 12-10-2026, 21:55.
07-04-2004, 19:27 Subject: Engine Failure: Causes and Solutions |
You haven't mentioned at what speed this occurred yet.
That's why I meant a misfire, because it can happen occasionally with speeds below 1500, causing the engine to stall. WELL, I'll just leave it at that.
But since it's a warranty case anyway, you don't have to worry about it affecting your wallet.  B.Eng (FH) u. KFZ Meister
Translated on 12-10-2026, 21:56.
wacken Guest
08-04-2004, 16:59 Subject: Engine Failure: Causes and Solutions |
Well, as I said, this has been a fairly rare occurrence so far, so I can't pinpoint the exact RPM range. And the warranty situation is complicated; I don't know what to tell Audi, they probably won't do anything anyway. I just wanted to know what the possible cause might be.
Translated on 12-10-2026, 21:57.
