TDI B4: Upgrade GRA (1992)
wolfi_b
Post23-02-2004, 19:56    Subject: TDI B4: Upgrade GRA (1992) Quote
Hello.
I want to retrofit a GRA (Gas Recirculation System) in my B4 TDI, manufactured in July 1992. I've already tried using the search function, but I haven't found a satisfactory answer. The most important question is whether this is even possible with my TDI icon_question.gif.
I would also be very grateful if someone could tell me which pins of the STG (Steuergerät - control unit) the steering column switch should be connected to, and what code is required to unlock it.
I hope you can help me.
Thank you very much, Woli.
Translated on 20-09-2026, 0:48.
mersente
Post23-02-2004, 20:18    Subject: TDI B4: Upgrade GRA (1992) Quote
Hello, it appears that your control unit is not yet configured for GRA.
The feature was only available on newer models.
Translated on 20-09-2026, 0:49.
wolfi_b
Post24-02-2004, 20:23    Subject: TDI B4: Upgrade GRA (1992) Quote
Thank you for the answer!
But the phrase "It seems like" makes it sound like you're not entirely sure. Is there a way to verify that?
Best regards, Wolfi.
mersente
Post24-02-2004, 21:16    Subject: TDI B4: Upgrade GRA (1992) Quote
I'm not 100 percent sure because there's a limit somewhere.
It applies to the 1994 model year IZ. However, I can't say exactly how much earlier it applies.
You can check the wiring diagram to see if there was an integrated starter (IZ) with GRA (glow plug relay) for your vehicle's year of manufacture.
If so, then you can also add it later.
Translated on 20-09-2026, 0:50.
FBonNET
Post24-02-2004, 22:41    Subject: TDI B4: Upgrade GRA (1992) Quote
I would like to retrofit a GRA (Gas Return Accelerator) in my B4 TDI, manufactured in 7/92. I have already tried using the search function, but I haven't found a satisfactory answer. The most important question is whether this is even possible with my TDI .
Could it be that you have the manufacturing year wrong? Because the B4 model wasn't introduced until August 1993, and that's when the 1Z engine was first used. In the older model, it should be an AAZ engine.
In this case, GRA could only be installed in conjunction with a mechanical vacuum pump.
Translated on 20-09-2026, 0:51.
mersente
Post24-02-2004, 23:07    Subject: TDI B4: Upgrade GRA (1992) Quote
Okay, I'll check on both of you tomorrow.
Translated on 20-09-2026, 0:52.
WarLord
Post25-02-2004, 20:27    Subject: TDI B4: Upgrade GRA (1992) Quote
Could it be that you have the manufacturing year wrong? Because the B4 model wasn't introduced until August 1993, and that's when the 1Z engine was first used. In the older model, it would have been an AAZ engine.
Well, who's here? FettesBruder, look who's back. Audi also had a B4 model, which was the last Audi 80; after that comes the B5 (A4).
Best regards, WarLord.
Wurstblinker
Post25-02-2004, 20:45    Subject: TDI B4: Upgrade GRA (1992) Quote
The 1Z model was already available in the B4 series starting in June 1992.
'MFG' is an abbreviation for 'Mit freundlichen Grüßen,' which means 'Sincerely' or 'Best regards' in English.
Translated on 20-09-2026, 0:53.
wolfi_b
Post25-02-2004, 20:57    Subject: TDI B4: Upgrade GRA (1992) Quote
Aha!
Then I probably got one of the first 1Z models with the production code 7/92.
I went to the service center today, but no one there really knew whether it would work or not.
Translated on 20-09-2026, 0:54.
mersente
Post25-02-2004, 21:05    Subject: TDI B4: Upgrade GRA (1992) Quote
Okay, I have something for you:
The Audi 80 IZ automatic can be upgraded with GRA starting from July 1993.
For manual transmission vehicles, starting with chassis number: wauzzz8czra128401.
The 'r' after the 'z' indicates the year of manufacture, with 's' representing 1995, 't' representing 1996, and so on.
After the letter 'a', a larger number is acceptable, and after the letter 'b', it is definitely acceptable.
Are all the ambiguities cleared up?
Translated on 20-09-2026, 0:55.
wolfi_b
Post26-02-2004, 22:54    Subject: TDI B4: Upgrade GRA (1992) Quote
Thus, you have destroyed my last hope icon_cry.gif.
I am very grateful for your answer, nonetheless!
Hi, Wolfi.
Translated on 20-09-2026, 0:56.
wolfi_b
Post11-04-2004, 19:24    Subject: TDI B4: Upgrade GRA (1992) Quote
Hello everyone.
Okay, since I have no other choice, I'm going to build a GRA myself. icon_idea.gif
(With microprocessor). Actually, that shouldn't be too much of a problem.
I have the following ideas/suggestions/plans:
I will use an original switch for operation.
When the GRA (Gear Ratio Adaption) is activated, the engine speed is kept constant and can also be adjusted using the "+" and "-" buttons. (There's a small issue: a single button press results in a different speed change depending on the selected gear, because the engine speed is being regulated. However, I don't think this should be a problem in everyday use).
When the clutch or brake is engaged, the GRA is deactivated, but it can be reactivated using the RECALL function (which retrieves the stored value).
Furthermore, I would like to switch from the accelerator pedal position sensor to an electronic potentiometer or DA converter using a relay when the GRA (Gas Response Amplifier) is activated. However, I am concerned that the control unit might report a sensor error during the switching time.
I hope you can answer my questions and that you have some suggestions for me.
But I have two more questions: What happens if the GRA is active and I press the accelerator pedal?? And what is the maximum RPM for a TDI when I increase the speed using the "+" button??
Greetings, Wolfi.
Translated on 20-09-2026, 0:58.
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts Retrofit BT for 9ZF Transmission Transmission, Chassis, Body & Interior
No new posts VW: Retrofitting LDA (Local Differential Analyzer) Diesel Engine Technology
No new posts Retrofit AHK for Galaxy 1999: Installation Guide On-Board Diagnostics (OBD)
No new posts Retrofitting MFA in VW Golf 3 TDI Transmission, Chassis, Body & Interior
