Gorchel Guest
06-05-2004, 8:05 Subject: Which diagnostic adapter? |
Hello.
I'm interested in a diagnostic adapter for my Skoda Fabia, but I'm a bit confused because there's such a wide selection available. Therefore, my question is:
Which adapter is recommended for 'hobby diagnostics' (e.g., reading error codes, modifying comfort functions, etc.)?
Thank you very much for your suggestions.
Ritchi.
Translated on 05-07-2026, 14:01.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
Profile PM WWW Garage |
Gorchel Guest
06-05-2004, 11:59 Subject: Which diagnostic adapter? |
Hi.
Thank you for the response.
How about this adapter?
http://shop.dieselschrauber.de/product_info.php/products_id/36
Is it significantly cheaper, but does that mean the options are severely limited?
Translated on 05-07-2026, 14:03.
x world one Blaumann
06-05-2004, 12:08 Subject: Which diagnostic adapter? |
You are missing the full version of VAGCOM, and you only have a serial port interface. The latter is not a problem if you still have an NB with a serial interface. With the included shareware, you can only log and read data, but as far as I know, you cannot set anything.
"For the adaptation, you'll need the full version, so that would be this bundle."
http://shop.dieselschrauber.de/product_info.php/products_id/45
Spritmonitor
Gorchel Guest
06-05-2004, 12:19 Subject: Which diagnostic adapter? |
Okay... I understand. And if this device also supports USB, that would be even better.
Thank you very much for your great help.
Ritchi.
Translated on 05-07-2026, 14:04.
06-05-2004, 13:54 Subject: Which diagnostic adapter? |
Only the last adapter recommended by Rainer supports USB!
I also ordered that one, and I hope it arrives soon http://shop.dieselschrauber.de/product_info.php/products_id/45.
Spritmonitor
