Coolant sensor location ARL: Find it here!
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post14-04-2006, 19:59    Subject: Coolant sensor location ARL: Find it here! Quote
Hello.
This week, I realized that my new car is using too much fuel; I simply can't get the average consumption below 8.5 liters. I've already read the error memory several times, and each time the same error code appears: "engine coolant sensor G62 open short to +" or something similar. I did some research and found that the increased fuel consumption is likely due to this sensor. It seems to be sending incorrect values to the engine control unit, making it believe the engine is still cold, which causes it to inject more fuel.
Now I'm looking for the sensor.
Is that the one that's located in the coolant reservoir? I don't think so, because it only measures the water level, right?
Sure, here's the translation:
"Thank you very much in advance."
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Audi SQ5 8R Cvub
Translated on 23-08-2026, 2:28.
Back to top Profile PM Email
Post14-04-2006, 23:22    Subject: Coolant sensor location ARL: Find it here! Quote
Hey, you don't have to create a new post for every single small thing.
The G62 sensor is obviously not located in the expansion tank. Why would you measure the temperature at such a location? The temperature is measured where the coolant leaves the engine, which makes perfect sense. It's located on the right side of the cylinder head, above and slightly forward of the tandem pump – this applies not only to the ARL but also to all other engines. Don't confuse it with the similarly shaped G81 sensor, which measures fuel temperature.
Checking the G62 sensor: With a cold engine, start the engine and read out parameter group (PG) 7. The temperature should increase. If the sensor is faulty, it will consistently display -5.4 degrees Celsius.
Alternatively, the sensor can be removed, and the internal resistance can be checked between the two pins located on the round side of the connector. At an ambient temperature of hopefully around 20°C, this resistance should be approximately between 2000 and 2500 ohms. If that is the case, check the cables.
Alternatively, the preheating time needs to be checked; when it's faulty, it consistently takes around 20 seconds for each start.
Translated on 23-08-2026, 2:30.
pa-mm6
Post14-04-2006, 23:35    Subject: Coolant sensor location ARL: Find it here! Quote
Hello.
Thank you for your reply.
This morning, I checked the calibration blocks.
In block 1, which displays the water temperature, it showed 12°C. Then I started the engine and the temperature rose. However, the error didn't reappear after I cleared it.
After I had turned off the engine for about 3 hours, the error reappeared.
"Engine Coolant Sensor: Open circuit or short circuit to positive terminal G62" (or something similar).
It seems like the error code reappears every time the engine cools down again.
I'm going to go to the Volkswagen dealership tomorrow and buy the sensor; I think it should cost around 20 euros. Then I'll replace it and hope that solves the problem.
Or do you know of anything better?
I've also disconnected the plug before, and there was no sign of corrosion.
Audi SQ5 8R Cvub
Translated on 23-08-2026, 2:33.
Post15-04-2006, 10:27    Subject: Coolant sensor location ARL: Find it here! Quote
Hi, please read the description; I didn't write it to annoy you. We don't have crystal balls here. I told you how to do it, but if you don't want to do it that way, feel free to buy the sensor... I'm out.
Translated on 23-08-2026, 2:35.
pa-mm6
Post15-04-2006, 17:55    Subject: Coolant sensor location ARL: Find it here! Quote
Hello.
I installed a new sensor today, and the error is gone so far icon_biggrin.gif. The fuel consumption is also slowly returning to below 8 liters, although I haven't driven much yet.
Many thanks again for your tips and assistance.
Audi SQ5 8R Cvub
Translated on 23-08-2026, 2:36.
No new posts Additional coolant heater for the TDI Technical Articles
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BKC Motor: LLK Location & Installation Guide Diesel Engine Technology
No new posts Wo sitzt die Staudruckklappe beim Golf III? Transmission, Chassis, Body & Interior
No new posts Where is the original timer relay for the STH system loca... Transmission, Chassis, Body & Interior
No new posts Golf 4: Location of Distance Sensor Diesel Engine Technology
