Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
14-04-2004, 20:54 Subject: Audi 80 B4 |
It's about an Audi 80 B4 manufactured in November 1991, with a 133 horsepower, 5-cylinder gasoline engine.
Although the car has a 2x2 pin diagnostic connector, no control unit can be accessed.
The pursuit of the K-Line led to nothing.
Does anyone have any ideas, or is it even possible to diagnose the car, despite the connector?
Translated on 05-07-2026, 10:52.
Profile PM WWW Garage |
knubbi Guest
15-04-2004, 4:53 Subject: Audi 80 B4 |
As far as I know, it's a KE Jetronic system.
There's not much to diagnose.
What problems does this item have?
Translated on 05-07-2026, 10:53.
Uwe@Ross-Tech Guest
15-04-2004, 5:31 Subject: Audi 80 B4 |
If it's a KE-Jetronic system, the engine control unit doesn't support 'fast data transfer,' so a VAG-COM diagnostic tool (which uses technology from around 1985) won't be able to communicate with the control unit. I've personally had a few vehicles with KE-Jetronic. You actually only need a multimeter and a fuel pressure gauge to perform all the diagnostics. (Okay, and a repair manual.)
-Uwe-
christians Profi-Schrauber
15-04-2004, 6:39 Subject: Audi 80 B4 |
The KE-Jetronic system used blink codes. By shorting the corresponding contacts, the engine check light would flash Morse code. I can check the Audi 100 Type 44 repair manual for specific details if needed. Gruß Christian
Translated on 05-07-2026, 10:54.
15-04-2004, 18:33 Subject: Audi 80 B4 |
Okay, so that clarifies things, thank you all! Unfortunately, I can't say anything about the problem. Perhaps the owner will comment on this later.
Translated on 05-07-2026, 10:55.
Thomas Falke Guest
15-04-2004, 19:30 Subject: Audi 80 B4 |
Hi, where did you get the diagnostic connector from? I also had one before, and it worked with the diagnostic system; it was also a 91 model, but with a 2-liter Monojetronic engine.
Question for everyone else: Why does he have a diagnostic connector if it's not supposed to be used for reading error codes?
15-04-2004, 21:52 Subject: Audi 80 B4 |
Thomas Falke wrote: | Hello, where did you get the diagnostic connector from? I also had one before, and it worked with the diagnostic system; it was also a 91. But it was only a 2-liter Monojetronic.
Question to the others: Why does he have a diagnostic connector if he's not supposed to be read out? |
Good question... next question please  .
No idea, I don't have access to the car (it's not mine).
Translated on 05-07-2026, 10:56.
faz Blaumann
1994 Audi 80 Premium Support
16-04-2004, 20:59 Subject: Audi 80 B4 |
For the ABS control unit... MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 05-07-2026, 10:57.
Profile PM Garage |
