Here is my version of the Climacodes. I would really appreciate any additions, confirmations, or corrections.
Climatronic system for a 1998 Passat.
Climate codes.
Press [ECON] + [Cooler] + [Blower Low] simultaneously.
If a plus or minus sign appears after a value, it means that the target value can be varied.
00 = Total value, 0 = maximum cooling, 255 = maximum heating.
01 = Interior temperature display (on the control panel of the Climatronic system).
02 = Average solar radiation index.
03 = Solar irradiance index in mW/cm².
04 = Average outside temperature, bumper.
05 = Outside temperature, bumper, current value.
06 = Temperature sensor, fresh air intake duct.
07 = Footwell outlet temperature.
08 = Indicates the exhaust temperature.
09 = Setpoint for blower voltage (+/-).
10 = Actual blower voltage in 10-1 volts.
11 = Temperature control valve (0 = maximum warm, 255 = maximum cold), (+/-).
12 = Center vent (0 = footwell/defroster, 255 = center), (+/-)
13 = Air intake control valve (0 = recirculation, 255 = fresh air), (+/-).
14 = Footwell/defroster vent (0=windshield, 255=footwell), (+/-)
15 = Time since engine start in seconds.
16 = Speed in km/h
17 = ? goes to 0, only positive values for climate compressor [ECON].
18 = ? usually = 0, but if it's very hot, even to the point where the cooling fan turns on, values are around 64 to 69 (correlation?).
19 = Compressor shutdown condition, 0 = none, 5 = speed too low, 6 = ECON mode, 7 = OFF, 11 = ?, 12 = ? (during...)
'Accelerate from a standstill,' '?=Outside temperature too low,' '?=Temperature.' Sensors defective, ?=coolant, ???=other.
20 = ? Regulation parameters: 0 to 100, where 100 represents the maximum cooling or heating level, and values decrease towards 0.
21 = ? Rule parameters, starting at 0, values between -100? and +100.
22 = ? Regulation parameters, when properly set, should result in small values around 0. Deviation?
23 = Actual value, outlet temperature, center.
24 = Setpoint for outlet temperature (plus/minus).
25 = Temperature control flap, warm setting.
26 = Actual temperature valve setting.
27 = Temperature control valve, cold setting.
28 = Central valve, foot pedal/defroster.
29 = Nominal value, central valve.
30 = Central valve, impact point at the center.
31 = Pressure relief valve, bypass valve, air recirculation.
32 = Static pressure valve setting.
33 = Damper, fresh air inlet.
34 = Footwell/Defroster vent control.
35 = Value of footwell/defroster flap.
36 = Footwell/defroster vent actuator, footwell area.
37 = Dwell time in minutes, (ignition off) 0 to 240 minutes.
38 = ? 20
39 = Time elapsed since ignition, 4 seconds. Beat.
40 = Deviation from the norm, Negative = cooling, Positive = heating.
41 = ? 0
42 = ? 8
43 = ? 0
44 = ? Mostly 0, but also 59.
Error memory.
By simultaneously pressing the [Convection] and [ECON] buttons for 3 seconds.
On the left, a three-digit error code appears, and on the right, the number 00. Pressing the '[Temp. +]' button displays the next error code. If the code 000 appears on the left, no further errors are stored. If the [ECON] button is pressed for longer than 3 seconds, the memory will be erased.
By pressing the [ECON] button, the normal display appears.
000 = Output finished.
30b = Temperature sensor, bumper.
444 = No errors stored.
511 = Footwell temperature sensor.
4F9 = Fuse 25 in the fuse holder, fan, magnetic coupling.
Self-diagnosis.
Ignition is off. Hold down the [Convection] and [ECON] buttons simultaneously while turning the ignition on, and wait for 3 seconds. -> The diagnostic process will begin. -> At the end of the test, the number '02' will appear on the right, and the error code will appear on the left (refer to the error code list).
