Passat VR6 automatic transmission
Thomas Falke
Post20-04-2004, 20:54    Subject: Passat VR6 automatic transmission Quote
Hello, I'm having a problem with a customer. The error code is: Control unit part number: 096 927 731 BF.
Component and/or version: AG4 transmission, part number 096 1521.
Encoding: 00000
Workshop code: WSC 00000.
'One error found:'
00545 - Electric connection for motor/transmission.
31-10 - Interruption / Short circuit to ground.
It's a Passat with a VR6 engine and an automatic transmission.
What should I search for to find the cable where the break is located?
I have another error in this fuel injection control unit; the error code is: Control unit part number: 021 906 258 CG.
Component and/or version: MOTOR PMC 2.
Encoding: 0261203211
Workshop code: 1267358111
1 error code found.
29-10 - Short circuit to ground.
'When the engine is running, they are constant, but when I only turn on the ignition, they appear intermittently.'
I have the feeling that the engine control unit is in a fault mode and that it's engaging in third gear. When I'm driving at 120 km/h and press the kickdown, it doesn't downshift. The kickdown switch seems to be working fine; I've already checked it.
Translated on 18-07-2026, 18:00.
Gremlin
Post20-04-2004, 21:08    Subject: Passat VR6 automatic transmission Quote
ei, hold the connection between the transmission control unit and the engine control unit... icon_rolleyes.gif
Does the Passat also have a specific name (or production year), and what are its engine code (MKB) and transmission code (GKB)?
You need to provide some information.
CU Gremlin.
Translated on 18-07-2026, 18:03.
No new posts Document: Automatic Transmission Leaks 01M Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN: Oil leak at upper internal thread screw, automatic t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Achsölwechsel im Automatikgetriebe 01M, Golf III Bj.: 1997 Troubleshooting & Guides
No new posts ZF 5HP19 automatic transmission problems in the VW Passat... Transmission, Chassis, Body & Interior
No new posts Automatikgetriebe Tiguan Diesel Engine Technology
No new posts Pfeifgeräusche Automatikgetriebe?! Diesel Engine Technology
No new posts Automatic Transmission Volkswagen Golf 3 Transmission, Chassis, Body & Interior
