Audi 80 B4
Post14-04-2004, 20:54    Subject: Audi 80 B4 Quote
It's about an Audi 80 B4 manufactured in November 1991, with a 133 horsepower, 5-cylinder gasoline engine.
Although the car has a 2x2 pin diagnostic connector, no control unit can be accessed.
The pursuit of the K-Line led to nothing.
Does anyone have any ideas, or is it even possible to diagnose the car, despite the connector?
Translated on 05-07-2026, 10:52.
knubbi
Post15-04-2004, 4:53    Subject: Audi 80 B4 Quote
As far as I know, it's a KE Jetronic system.
There's not much to diagnose.
What problems does this item have?
Translated on 05-07-2026, 10:53.
Uwe@Ross-Tech
Post15-04-2004, 5:31    Subject: Audi 80 B4 Quote
If it's a KE-Jetronic system, the engine control unit doesn't support 'fast data transfer,' so a VAG-COM diagnostic tool (which uses technology from around 1985) won't be able to communicate with the control unit. I've personally had a few vehicles with KE-Jetronic. You actually only need a multimeter and a fuel pressure gauge to perform all the diagnostics. (Okay, and a repair manual.)
-Uwe-
christians
Post15-04-2004, 6:39    Subject: Audi 80 B4 Quote
The KE-Jetronic system used blink codes. By shorting the corresponding contacts, the engine check light would flash Morse code. I can check the Audi 100 Type 44 repair manual for specific details if needed.
Gruß Christian
Translated on 05-07-2026, 10:54.
Post15-04-2004, 18:33    Subject: Audi 80 B4 Quote
Okay, so that clarifies things, thank you all! Unfortunately, I can't say anything about the problem. Perhaps the owner will comment on this later.
Translated on 05-07-2026, 10:55.
Thomas Falke
Post15-04-2004, 19:30    Subject: Audi 80 B4 Quote
Hi, where did you get the diagnostic connector from? I also had one before, and it worked with the diagnostic system; it was also a 91 model, but with a 2-liter Monojetronic engine.
Question for everyone else: Why does he have a diagnostic connector if it's not supposed to be used for reading error codes?
Post15-04-2004, 21:52    Subject: Audi 80 B4 Quote
Thomas Falke wrote:
Hello, where did you get the diagnostic connector from? I also had one before, and it worked with the diagnostic system; it was also a 91. But it was only a 2-liter Monojetronic.
Question to the others: Why does he have a diagnostic connector if he's not supposed to be read out?
Good question... next question please icon_cool.gif.
No idea, I don't have access to the car (it's not mine).
Translated on 05-07-2026, 10:56.
faz
Avatar-faz
1994 Audi 80
Post16-04-2004, 20:59    Subject: Audi 80 B4 Quote
For the ABS control unit...
MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 05-07-2026, 10:57.
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts LOG Audi 2.5 AKE Upload
No new posts Audi AFB STG: Repair & Replacement Diesel Engine Technology
