Golf Engine Stalling: Warm Engine Problems
voss
Post29-04-2004, 20:07    Subject: Golf Engine Stalling: Warm Engine Problems Quote
Hello.
It's not a TDI or even a diesel engine, but I'm still trying to make it work.
Golf, manufactured in 1998, with approximately 21,000 km and the following problems:
Sometimes, usually on Thursdays and when the engine is warm, it starts very poorly, and then it smells like gasoline.
-Thursday error javascript:emoticon('icon_lol.gif') ,
With a little help from the accelerator, it should start up quickly.
Meiner Meinung nach, ist der Motor ersoffen. But why?
Error code: Engine - Coolant temperature sensor (G62).
Open or short circuit to B+ intermittent.
Or something like that? Does the error disappear after deleting [something]? But it still has trouble starting, right?
In the "measurement block," it displays the temperature in a plausible way.
Can someone with experience or some ideas help me out here?
Sure, here's the translation:
"Thank you in advance."
voss
Translated on 20-08-2026, 14:17.
Marco
Post29-04-2004, 20:17    Subject: Golf Engine Stalling: Warm Engine Problems Quote
Hi Voss,
The control unit isn't fabricating the G62 error; it's actually detecting a problem. The symptoms also suggest a faulty temperature sensor. It's best to re-examine the issue carefully and check the sensor along with its wiring connections. The control unit's error message indicates that the 'error: temperature sensor' doesn't always occur, which is why there hasn't been another error entry yet.
Translated on 20-08-2026, 14:19.
voss
Post29-04-2004, 20:33    Subject: Golf Engine Stalling: Warm Engine Problems Quote
Hi Marco,
Thank you for your reply.
"I understood that the error was intermittent, but I'm wondering why the car is having trouble starting and why the error doesn't reappear. I experienced this poor starting issue after several attempts, but the values in the engine control unit (ECU) seemed reasonable."
voss
Translated on 20-08-2026, 14:20.
Marco
Post29-04-2004, 20:54    Subject: Golf Engine Stalling: Warm Engine Problems Quote
Hi Voss,
Are you absolutely sure that your measurement captured the G62 sensor? Unfortunately, I have no idea which sensor the G62 represents for this vehicle! It could be the oil, coolant, or fuel temperature sensor. What is the engine code (MKB) of the vehicle?
Translated on 20-08-2026, 14:21.
voss
Post29-04-2004, 21:09    Subject: Golf Engine Stalling: Warm Engine Problems Quote
Hello.
As the title suggests, AKQ.
and I thought that the water temperature was displayed in measurement block 1.
voss
Translated on 20-08-2026, 14:22.
Marco
Post29-04-2004, 21:44    Subject: Golf Engine Stalling: Warm Engine Problems Quote
You're right! I checked, and the G62 is the coolant temperature sensor.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post29-04-2004, 22:13    Subject: Golf Engine Stalling: Warm Engine Problems Quote
If the engine has flooded multiple times, try replacing the spark plugs.
They absolutely hate moisture.
Another possibility is that the fuel injector(s) might drip, which could lead to problems.
B.Eng (FH) u. KFZ Meister
Translated on 20-08-2026, 14:23.
No new posts Golf 5 / Audi A3 2004 BKC-Motor stirbt ab, startet nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV TDI starts poorly when the engine is warm - DKE i... Diesel Engine Technology
No new posts Engine Performance Loss: Causes & Solutions Diesel Engine Technology
No new posts Compression test: warm or cold engine? Diesel Engine Technology
No new posts Rough Idle in Hot Weather: Causes & Fixes Diesel Engine Technology
