Problems with the air conditioner
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
reinholdl
Post04-05-2004, 18:32    Subject: Problems with the air conditioner Quote
Hello.
The air conditioning system (Climatronic) in my Audi A4, manufactured in 9/1996, is not working; it's not providing any cooling.
VAG COM shows the following errors:
VAG-COM Version: Release 303.1
Control Module Part Number: 8D0 820 043 H
Component and/or Version: A4-KLIMAVOLLAUTOMAT_D65
Software Coding: 00043
Workshop Code: WSC 06335
2 faults found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent.
00602 - Potentiometer on positioning motor for footwell/defroster flap (G114).
37-10 - Defective - Intermittent.
Question: Where are V71 and G114 located, and how are they controlled?
Could these error messages be responsible for the lack of cooling performance?
I am very grateful for any advice.
Reinholdl.
Translated on 16-07-2026, 9:13.
mersente
Post07-05-2004, 23:34    Subject: Problems with the air conditioner Quote
Hello, so when you turn on the air conditioning, does the compressor start running?
Do the pipes leading to the dryer run near the spray booth?
Translated on 16-07-2026, 9:15.
Goldhuhn
Post09-05-2004, 23:11    Subject: Problems with the air conditioner Quote
I've been dealing with this kind of stuff recently, and I assume that your Audi A4 from the year 1996 has the same climate control system as mine.
I had already written a lengthy post http://www.motor-talk.de/t308371/f162/s/thread.html in another forum about the specific error diagnosis. This should help you determine which shutdown condition in channel 52 ultimately caused the compressor failure. The failure of the V71 actuator has nothing to do with a shutdown condition of the compressor; it should still be running and seems to be another defect, but you will definitely see this indicated on the segment displays http://www.meckisfaq.de/antworten/allgemeines/klimacodes/Klimacodes61.htm.
See how far you can go.
Seit 221tkm Feb.03 Audi A6 Avant C4, 2.5 TDI, 103KW 140PS, Bj.96, Motor AEL, Getriebe DCF Automatik, Standheizung ab Werk Webasto DBW46
Translated on 16-07-2026, 9:16.
No new posts Air conditioner smells bad General Tips
No new posts Empty the air conditioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8P1, Klimaanlage kühlt nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problems with ventilation and manual air conditioning Transmission, Chassis, Body & Interior
No new posts Air conditioner! Huge problems... who knows the answer? Transmission, Chassis, Body & Interior
No new posts Air conditioner advice Transmission, Chassis, Body & Interior
No new posts Klimaanlage Transmission, Chassis, Body & Interior
