| Spark plug firing order | |||||
| michiglaser |
Hello!
Simple question that could probably also be answered through a search if I knew what to search for My Audi (ASB-TDI) is reporting a faulty glow plug via the diagnostic system – specifically, "glow plug 1." Where is spark plug number 1 located? Assuming the naming convention is consistent with the cylinder numbering, I need to know which cylinder is designated as number one. Thank you very much Greetings, Michael. T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC) G4 (ASZ), T4 (AXG) Translated on 11-07-2026, 12:17. |
| dieselmartin |
Vuck. It's a V-engine.
... there was another T. I don't know what the f*ck it was. Translated on 11-07-2026, 12:21. |
| christians |
For V-engines mounted at the front, it looks like this:
Damn. 3 6 2 5 1 4 front Gruß Christian
A6 BPP, Ex-A6 AKN (Gurke), Ex-Audi100 92 AAT (5Zyl.) Translated on 11-07-2026, 12:24. |
| michiglaser |
Strong, thank you very much
A4 B8 Avant (CDUC) G4 (ASZ), T4 (AXG) Translated on 11-07-2026, 12:24. |
| TDI-GTI-4-Motion |
This is how counting is done according to the standard. However, very few people follow this method when it comes to V engines. Most people count the cylinders in a V engine diagonally (crosswise). Damn. 5 6 3 4 1 2 front MfG. Michael
VW Golf IV TDI GTI 4-Motion Bj.2002 MKB/GKB: ARL/FEK VW T4 Pritsche TDI Bj.1999 MKB/GKB: AXG/AFK (Selfmade) Translated on 11-07-2026, 12:25. |
| christians |
Audi is present, but it complies with the regulations.
Gruß Christian
A6 BPP, Ex-A6 AKN (Gurke), Ex-Audi100 92 AAT (5Zyl.) Translated on 11-07-2026, 12:26. |
| vwSchrauber |
Caution In the 2.8 TDI engine, with code AUH, found in the LT van, cylinder number 1 is located at the rear, near the timing chain housing. If you don't believe it, remove the injector from what appears to be the first (frontmost) cylinder and then check the error memory In Deutz tractor engines, the first cylinder is also located on the power output side. selber schrauben - statt Werkstattpfusch Translated on 11-07-2026, 12:27. |
| Ratings - Spark plug firing order | |
Average rating: 0.00 - worst rating: 0 - best rating: 0 - number of ratings: 0 - View ratings |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.039s
