Heckwischer A6: The Ultimate Guide
bastianna
Post25-02-2005, 10:02    Subject: Heckwischer A6: The Ultimate Guide Quote
Hey everyone,
I recently used the rear wiper on my A6 with the 5-cylinder engine (AEL) for the first time – I've owned the car for two years already. Now I've noticed that the wiper only runs in intermittent mode and doesn't turn off. I can only switch it off by turning off the ignition!
Is this normal, or is a relay defective?
Hi Bastianna,
Das Leben ist schön, wenn man es lebt.
Translated on 25-08-2026, 8:28.
Wurstblinker
Post25-02-2005, 11:27    Subject: Heckwischer A6: The Ultimate Guide Quote
Hi there,
That sounds very much like a faulty relay!
By the way, this relay is located in an additional relay holder under my rear seat; it might be hidden there for you as well!
'MFG' stands for 'Mit freundlichen Grüßen,' which translates to 'Sincerely' or 'Best regards' in English. It is a common way to end a formal letter or email.
Translated on 25-08-2026, 8:29.
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post25-02-2005, 12:30    Subject: Heckwischer A6: The Ultimate Guide Quote
I'm not familiar with the Audi model, but Volkswagen used to have a version with a button instead.
Is the lever for the rear wiper properly engaged, or is it perhaps just a button (where the lever springs back after being pressed)?
Translated on 25-08-2026, 8:30.
LZ
Post25-02-2005, 14:07    Subject: Heckwischer A6: The Ultimate Guide Quote
You can only turn it off by pressing the wiper switch again, but only if the wiper is not currently in its resting position. It's a bit silly, but there's no other way to do it with just one button.
Best regards, Robert.
olli
Karma: +46 / -0   Thank you, like it!
Post25-02-2005, 20:45    Subject: Heckwischer A6: The Ultimate Guide Quote
Hi there,
Turning it off is also possible in standby mode, but then it will wipe the data again before shutting down icon_smile.gif.
Best regards from Berlin.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 25-08-2026, 8:31.
bastianna
Post26-02-2005, 8:54    Subject: Heckwischer A6: The Ultimate Guide Quote
Hello everyone,
...is a toggle switch and springs back to its original position immediately.
Knowledge is power, and not knowing anything doesn't matter either; I can learn a lot from many experienced diesel mechanics and enthusiasts in this forum!
Thank you for your responses.
Hi Bastianna,
Translated on 25-08-2026, 8:32.
wolle
Post01-03-2005, 0:40    Subject: Heckwischer A6: The Ultimate Guide Quote
@bastiannaViewing profile: bastianna,
If you activate the lever twice in a row, it will only wipe once. The intermittent wiper function will not be activated. If you hold the lever down for a slightly longer time to also pump windshield washer fluid onto the glass, the intermittent wiper function will still not be activated.
The interval mode is only activated when the lever is briefly and simply operated.
Wool.
Translated on 25-08-2026, 8:33.
No new posts Polo Heckwischer: 3GP Video Download On-Board Diagnostics (OBD)
No new posts Rear-wheel drive VW Passat, manufactured in 1998 Diesel Engine Technology
No new posts Sharan 7M - welches Relais f. Heckwischer? On-Board Diagnostics (OBD)
No new posts Rotating Rear Wiper Nozzle (VW Golf 4) Transmission, Chassis, Body & Interior
