Can I still cancel the equipment?
eike
Post07-05-2004, 20:54    Subject: Can I still cancel the equipment? Quote
I have already asked this question elsewhere, but unfortunately I haven't received an answer yet. I'm trying it again here in the hope that someone knows:
Can I cancel optional features when ordering a special model?
I am considering ordering a Golf Pacific, but I would prefer to avoid the large alloy wheels with the expensive tires, and instead opt for steel wheels with 195/60 R15 tires. Can I unsubscribe and receive a price adjustment?
There must surely be some who know about being friendly and helpful.
In my previous Golf Special, it worked fine. However, a colleague recently told me that it was no longer possible.
Who knows exactly?
Greetings
Eike
mersente
Post07-05-2004, 23:30    Subject: Can I still cancel the equipment? Quote
Hello, you can try to see if your friendly person installs different wheels and keeps the old ones. Maybe he will even give you some money. Otherwise, you probably won't be able to cancel the 'shoes' easily.
Julian
Post07-05-2004, 23:57    Subject: Can I still cancel the equipment? Quote
If it is not offered as an option, there is nothing that can be changed. It then lies at the discretion of the dealer to comply with your request.
Post08-05-2004, 12:22    Subject: Re: Can I still cancel the equipment? Quote
So, bezüglich des Pacific-Modells kann ich nichts dazu sagen, aber beim Spezialmodell gab es die Option "Entfernung der Aluminiumräder" (gegen einen geringeren Preis... siehe Anhang).
 File size:  9.33 KB
 Viewed:  685 times
This topic is locked, you cannot edit or reply. Air Filter Mystery: Can It Be Solved? Diesel Engine Technology
No new posts Cancel Options on Custom Models Transmission, Chassis, Body & Interior
No new posts Kann man Zündaussetzer auslesen? On-Board Diagnostics (OBD)
No new posts Can the radio code be read out? Electrical Systems, Vehicle Electronics, Multimedia
