Clutch Housing Plugs & NW Adjustment PD
ckone
Post12-05-2004, 11:25    Subject: Clutch Housing Plugs & NW Adjustment PD Quote
Hi!
Today, I adjusted the camshaft using Ulf's method. To do this, I had to read the top dead center (TDC) position on the flywheel.
I just noticed that there wasn't a cover on the casing to protect the balance wheel, which is why the teeth of the wheel are slightly rusted. I've already reordered the cover.
Could this cause problems now?
Thank you.
Translated on 05-09-2026, 15:47.
D.
Post12-05-2004, 13:12    Subject: Clutch Housing Plugs & NW Adjustment PD Quote
I also had the plug missing after the belt replacement at the 'friendly' (referring to a car dealership or repair shop).
It seems to be the 'norm' or 'custom.'
I didn't replace the stopper until about a year later. I haven't experienced any problems so far.
Translated on 05-09-2026, 15:48.
Post12-05-2004, 13:50    Subject: Clutch Housing Plugs & NW Adjustment PD Quote
If the plug is missing for a long time, the rust on the gear ring can cause the starter motor to have increasing difficulty engaging, disengaging, and especially turning. Therefore, it's not ideal if the plug is missing, but if there haven't been any problems so far and a new plug is expected soon, it's likely that no problems will arise.
Translated on 05-09-2026, 15:49.
Post12-05-2004, 15:42    Subject: Clutch Housing Leak: Missing Plug Caused Rust. Fix? Quote
ckone wrote:
Today, I adjusted the camshaft using ulf's method...
How much was the initial setting incorrect by?
If at all, do you notice any difference between before and after?
I'm interested because PDs are often said to have a lack of power at the top... maybe sloppy NW (Northwest) settings are a widespread problem?
Translated on 05-09-2026, 15:50.
ckone
Post12-05-2004, 16:52    Subject: Clutch Housing Plugs & NW Adjustment PD Quote
It was misaligned by at least 3-4 degrees.
Subjectively, I experience more power in the higher RPM range, which is most noticeable on the highway. It achieves a top speed that is 5 km/h faster, which I consider to be quite a significant difference.
He also improved by approximately 0.4 seconds in the acceleration test.
Translated on 05-09-2026, 15:51.
Post12-05-2004, 19:26    Subject: Clutch Housing Plugs & NW Adjustment PD Quote
ckone wrote:
It was misaligned by at least 3° to 4°.
Look at that... with Boeckler's and my engine, it was practically the same.
It's becoming increasingly unlikely, in my opinion, that these are just isolated incidents.
Translated on 05-09-2026, 15:52.
WarLord
Post12-05-2004, 20:01    Subject: Clutch Housing Plugs & NW Adjustment PD Quote
'Hmm, ours (115 HP, PD, ATJ) has already had its timing belt replaced, and it's quite lively, you could say. It revs willingly and without any noticeable loss of torque up to 4,500 rpm, but then it starts to lose power.'
Best regards, WarLord.
No new posts VCDS: Adjusting Glow Plug Timer on VAG TDIs Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Engine tuning box installation Diesel Engine Technology
No new posts RWG-Position at AFN? Diesel Engine Technology
No new posts VP37 Job Opening: Apply Now! Diesel Engine Technology
No new posts VAG Com - Easily make adjustments Diesel Engine Technology
