Upgrading brakes from a 90 HP TDI to an Audi S3
Alpine
Post23-05-2004, 10:12    Subject: Upgrading brakes from a 90 HP TDI to an Audi S3 Quote
Unfortunately, I haven't found it yet...
I would like to increase the size of my front brakes.
Currently, the front axle is equipped with 280mm brake discs and the FSIII caliper.
It would be interesting to upgrade to the larger brake system that is also used in the S3, TT (I believe the Golf V6), etc. It's the large saddle and the 312mm disc.
The saddle mount is a different design, that's clear. But is it enough to just take the S3 axle bracket, or do I need other parts as well?
Best regards, Andreas.
Translated on 04-07-2026, 14:46.
Stefan .
Post23-05-2004, 14:01    Subject: Upgrading brakes from a 90 HP TDI to an Audi S3 Quote
You need the wheel bearing housing, new seat stays, new brake calipers, rotors, and pads.
Just the calipers cost €118 each (!), plus the brake discs (each €119), rotors (each €127), pads (€121), and heat shields (€5).
The wheel bearing housing costs about 150,-, but if you don't have a Quattro model, you should get one from a 1.8T with front-wheel drive, not one from the S3.
icon_wink.gif Stefan.
Translated on 04-07-2026, 14:48.
Alpine
Post23-05-2004, 14:49    Subject: Upgrading brakes from a 90 HP TDI to an Audi S3 Quote
[img][/img]
Thank you for your quick response!
Does that mean it would take that long?
'But it's from an S3, and I don't have Quattro!'
Andreas.http://people.freenet.de/alpine71/a5_1.jpg{MARKER}
Translated on 04-07-2026, 14:49.
Stefan .
Post23-05-2004, 15:00    Subject: Upgrading brakes from a 90 HP TDI to an Audi S3 Quote
Yes, it looks like it would fit (except for the cover plate).
I'm not familiar with the differences between the Quattro and non-Quattro front axle components (even though there are differences, at least in the part numbers).
It should fit; try it out.
Translated on 04-07-2026, 14:50.
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi S4 Brakes for VW Bora: Upgrade Guide Transmission, Chassis, Body & Interior
No new posts Audi A4 brake problem - Please help! Transmission, Chassis, Body & Interior
No new posts Audi A4 B8, rear left brake warm Transmission, Chassis, Body & Interior
No new posts Turbocharger Installation: Guide & Tips Diesel Engine Technology
