Small bumps
Uwe
Post19-04-2002, 14:15    Subject: Small bumps Quote
Hi!
Do your car also have small dents on the side, caused by the careless neighbor? My garage removed some of these Aldiparkplatzbeulen for me - without repainting. The work was carried out by a third-party company at Audi. They are supposedly available throughout Germany. The cost is 99 euros for a body part, including a maximum of 5 small dents on undamaged paint. I can highly recommend this method. You can't see anything behind!
Best regards, Uwe
Post19-04-2002, 14:23    Subject: What is the method? Quote
When it comes to removing dents from smooth surfaces, the only method I know is using a tennis ball.
Hello, Rainer
Holger
Post19-04-2002, 16:45    Subject: Small bumps Quote
with the tennis ball, it only works if you do it from the inside.
arrives.
What Uwe probably means is pulling from the outside.
They stick a pen in the hole and then pull it out with
a device with a thread on it until the bump is gone.
Finally, the tool is removed and the area is polished.
Uwe
Post19-04-2002, 20:51    Subject: Small bumps Quote
Hi!
Unfortunately, I wasn't there when my car was being repaired. Therefore, I didn't see them doing the work. The mechanic said that they were also pushing from the inside, and that the trim had to be removed. I don't believe it, as they only had about 2 hours to work on the car, and 99 euros is very little money for extensive repairs.
How does the tennis ball method work?
Best regards, Uwe
Post20-04-2002, 14:39    Subject: Tennisball is nix besondres... Quote
... this essentially involves applying pressure from the inside to create a smooth and even pressure on the lump.
Hello, Rainer
Olaf
Post22-04-2002, 22:39    Subject: Small bumps Quote
The company can probably be found at www.scratch-repair.de
Greetings
Olaf
Back to top Profile PM Email
No new posts Gear Questions: Small & Simple Answers Transmission, Chassis, Body & Interior
No new posts VAG COM 607: Quick Question On-Board Diagnostics (OBD)
No new posts Air Filter Replacement VW Passat 35i TDI 1Z Diesel Engine Technology
