AJM Water Temperature: How to Check & Adjust
chli1976
Post24-05-2004, 10:14    Subject: AJM Water Temperature: How to Check & Adjust Quote
While driving at a fast pace, I logged the coolant temperature on a Golf IV with a AJM engine. (The coolant temperature gauge normally shows a reading between 75°C and 105°C, but always indicates 90°C, which is considered normal by VW).
According to VAG-COM, the engine (AJM) can reach up to 98°C when driven at a brisk pace. I have tested this on two Golfs with the AJM engine, and the result is always the same.
I tested it on a 90 HP TDI engine, which only reaches 90°C under the same driving conditions.
However, the thermostat should be the same for both engines, with an opening temperature of 87°C.
Does anyone have any idea, or any comparable values, or is this normal for this engine?
Translated on 29-08-2026, 4:51.
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Water Temperature AKN Diesel Engine Technology
No new posts Audi 80 B4 TDI: Coolant Temperature Issues Diesel Engine Technology
No new posts Fluctuating water temperature gauge, 1.9 TDI AVG Diesel Engine Technology
No new posts Water Temperature After Tuning: Optimization Tips Diesel Engine Technology
