The climate control shuts off at 2500 RPM
martin119
Post27-05-2004, 7:15    Subject: The climate control shuts off at 2500 RPM Quote
My air conditioning shuts off as soon as the engine speed exceeds 2500 RPM. It only starts cooling again when I turn off the engine and restart it.
What could that be?
Martin.
Translated on 18-07-2026, 17:27.
Julian
Post27-05-2004, 8:45    Subject: The climate control shuts off at 2500 RPM Quote
Overpressure or underpressure in the system. Has anything been done to it? Error codes read --> Result?
Translated on 18-07-2026, 17:28.
Martin R
Post27-05-2004, 12:30    Subject: The climate control shuts off at 2500 RPM Quote
Is the V-belt still in good condition and properly tensioned?
Otherwise, I would also have the pressure checked first and see what the error memory says.
Does it still cool properly, or has the cooling performance also decreased?
Is the fan still working properly?
Translated on 18-07-2026, 17:29.
martin119
Post27-05-2004, 14:02    Subject: The climate control shuts off at 2500 RPM Quote
Okay, so it's cooling normally like always, which means not very well, especially the ventilation. I already replaced the filter once, but I still think it makes more noise than air movement. Could it be that some of the vents aren't opening properly?
I had the coolant changed last year, and it was a bit cooler afterwards.
Is there a protective function that now shuts off the climate control above 2500 RPM because something is not working correctly?
Translated on 18-07-2026, 17:30.
No new posts Interior Lights Turn On Late: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Touran: GRA Disengagement Explained Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Smart Fortwo: Gear won't shift from Neutral to Drive General Tips
No new posts 3C: Better Performance in Rainy Weather Transmission, Chassis, Body & Interior
No new posts schlapper ALH,ab 2500 U/min Leistungssprung->VW: is OK s Diesel Engine Technology
No new posts Loud Humming Noise at 2500 RPM Diesel Engine Technology
No new posts Oil pressure dropping to 1 bar at 2500 RPM on a 1.6L TDI ... Diesel Engine Technology
