Injection Timing: 17 Degrees BT - Is It Safe?
wurbel
Post08-07-2005, 11:11    Subject: Injection Timing: 17 Degrees BT - Is It Safe? Quote
...definitely not, because I thought my exhaust was broken, that thing was making such a loud noise (engine code 1z).
I couldn't log any data because I was only using VDS_pro on an old laptop, but the target value was supposed to be around 3 degrees, while the actual reading consistently stayed at 16-17 volts.
Connected VAG-Com at home, checked channel 000, and initially fiddled with all the cables - and there it was! The 3-pin connector to the control valve/injector N108; the value displayed in table 2 is fluctuating between 0 and 255.
The main cable (pin 2) was damaged right at the connection point to the coupling. There's still some corroded cable about 3 cm behind the coupling!
It was repaired, and it worked again - All thanks to this forum! Thanks to everyone!
But... a strange side effect => my engine, which usually needs a lot of coaxing and 1-3 batteries to start, started perfectly (in other words: top-notch) with the defect?! I even tested it again - connected the cables - and it still started easily...
Disconnecting the cable - buzzzzzzz.
Has anyone ever experienced this before, or can someone explain it to me?
Translated on 16-08-2026, 18:57.
ObenbeiMutti
Post08-07-2005, 14:38    Subject: Injection Timing: 17 Degrees BT - Is It Safe? Quote
Isn't that already considered 'knocking' of the engine icon_wink.gif?
...duck and cover?
Translated on 16-08-2026, 18:59.
No new posts LPG injection Diesel Engine Technology
No new posts Engine Control Unit / Injection Mondial SMX 125i Gasoline Engine Technology
No new posts Fan starts at 97.8°C - Is this normal? Diesel Engine Technology
No new posts Deactivate fuel injection after oil change Diesel Engine Technology
