Intake Manifold Pressure Regulation Difference
Go to page: 1, 2  Next
alca
Post12-04-2004, 19:50    Subject: Intake Manifold Pressure Regulation Difference Quote
Hello.
Here we go again with this annoying bug. I think I've read all the posts that have been published about it by now.
Well, I'm not much of a mechanic myself, but I've tried to follow some suggestions, but I haven't found anything yet that triggers this error.
Background:
On December 24, 2003, my TDI 1Z engine (133,000 km) manufactured in 1996, decided to give up and completely fail. The turbocharger also failed.
So, off to the workshop. First, only the turbo was replaced, as the engine started normally when stationary, but ran unevenly and had no power.
The old turbo was, among other things, full of oil.
So Turbo getausch (auf den alten Motor), aber keine änderung --- also.. Motor defekt / getauscht (Austauschmotor mit Anbauteile Fa. Meyer)
Now I no longer have a 1Z engine, but an AHU engine.
€3800 including a new clutch, to be installed later.
Everything is running 100%.
At some point, this error appeared for the first time. I did some searching, but couldn't find anything. I eventually replaced the valve (N75) with a new one.
'Despite this, the error occurs repeatedly, but I can't say that it happens specifically at 130 km/h or 150 km/h, or in any particular situation. It has even happened when starting from a standstill at a traffic light. Restarting the engine restores power to the car.'
(For Bosch diagnostic tools, this error code is 023F.)
My first question: Is the turbocharger from the 1Z engine the same as the AHU engine?
My second question: Where can I find the vacuum sensor, or what does it look like (for the purpose of checking it)?
My third question: Does anyone know of a good workshop in the area of Dortmund/Recklinghausen that specializes in...?
Perhaps someone here is familiar with this?
Does anyone else have any ideas?
I'm already starting to get bored.
Thank you very much for your efforts.
CU.
Translated on 29-08-2026, 12:41.
Post13-04-2004, 11:59    Subject: Intake Manifold Pressure Regulation Difference Quote
Hi.
The 1Z and AHU engines are largely identical. The turbochargers should be the same, but the pipes behind them (flex pipe and catalytic converter) are not.
The 1Z and AHU engines DO NOT have a vacuum chamber! They have a pressure chamber, and it's located on the turbocharger (where else would it be)?
Where does the boost pressure deviate (is it too high, too low???)?
Without specific values, it's unfortunately impossible to provide a helpful response to such vague "it's not working" error descriptions, other than:
- Log the values.
- post the values.
Check all the tubes (some of which are thin and may be red or blue) to make sure they are sealed and not porous.
Translated on 29-08-2026, 12:45.
alca
Post13-04-2004, 18:51    Subject: Intake Manifold Pressure Regulation Difference Quote
Hi.
Thank you for your response.
I would love to log data and post it here in the forum, but as I mentioned before, there is no specific indication of which driving style triggers this error (emergency program).
I've already used the VAG-Com diagnostic tool several times, but on longer trips, everything seemed fine. There were no error codes, the performance was good, and nothing seemed unusual.
Okay, this Saturday I'm going on a longer trip again (400 km). I'll try to log it and see what happens.
Therefore, I cannot determine whether the pressure is too high or too low when this error occurs.
'cu' is a Spanish abbreviation for 'con usted,' which means 'with you.' It is often used in online communication to indicate that the sender is available to chat or talk.
Here is an example of how 'cu' might be used in a conversation:
Person A: 'Hey, I'm bored. Want to chat?'
Person B: 'Cu!'
This means that Person B is available to chat with Person A.
'Cu' can also be used to indicate that the sender is thinking about the recipient. For example, if Person A is thinking about Person B, they might send a message that says, 'Cu.'
In general, 'cu' is a friendly and informal way to communicate with someone online.
Translated on 29-08-2026, 12:47.
Post13-04-2004, 20:21    Subject: Intake Manifold Pressure Regulation Difference Quote
"A boost pressure display should be in every TDI": the expert article had exactly this title icon_wink.gif icon_cool.gif.
Translated on 29-08-2026, 12:48.
alca
Post17-04-2004, 19:43    Subject: Intake Manifold Pressure Regulation Difference Quote
Hi.
I drove 800 km today, and 99% of the time, it was a terrible experience.
I connected VAG-Com and logged the data (I'll be able to attach the log file here tomorrow), but I noticed something:
The number 023 displays the pressure of the turbocharger. How are the four fields in which the values are displayed structured?
1 = should be 'durch'
2 = is 'Druck'
If so, then I never reached the maximum desired pressure, which was supposed to be 1979 mbar.
and the - The air pressure was approximately 1480-1500 millibars.
Could this difference be causing the error 'Intake manifold pressure regulation difference'?
If so, I'll be a giant step closer and be able to search more specifically.
Thank you very much.
Person B: 'Cu!'
Translated on 29-08-2026, 12:50.
Post17-04-2004, 19:55    Subject: Intake Manifold Pressure Regulation Difference Quote
alca wrote:
if so, then I never reached the maximum desired pressure - desired, which was 1979 mBar.
Could it be that this difference triggers the error "Intake manifold pressure regulation difference"???
Okay.
The reduced pressure on sensor 1Z indicates that the magnetic valve is not functioning properly, or that the turbocharger is directly receiving the full boost pressure -> are the hoses connected incorrectly?
Translated on 29-08-2026, 12:52.
alca
Post18-04-2004, 12:13    Subject: Intake Manifold Pressure Regulation Difference Quote
Does anyone happen to have pictures showing how the hoses need to be connected?
As mentioned before, I received a new engine, and it's possible that a mechanic may have swapped the hoses.
Person B: 'Cu!'
Translated on 29-08-2026, 12:53.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post18-04-2004, 12:25    Subject: Intake Manifold Pressure Regulation Difference Quote
Hi!
Try your luck here.
/viewtopic.php?t=3101
I think this is very well done and easy to understand!
Dirk.
Translated on 29-08-2026, 12:54.
alca
Post19-04-2004, 20:19    Subject: Intake Manifold Pressure Regulation Difference Quote
Hi.
I still have one question at the moment: as previously mentioned, what is the meaning of code number 023 in the VAG-Com system?
There are 4 small windows, and the first two each have the word 'Absolute Value' written below them.
Is the first window the 'target' pressure that needs to be achieved, and is the second window the 'actual' pressure that should reach the 'target' pressure (window 1)?
I just don't want to start looking in the wrong direction again.
Is there a good VAG-COM manual that explains the meaning of the codes?
Person B: 'Cu!'
Translated on 29-08-2026, 12:56.
joergs
Post19-04-2004, 20:34    Subject: Intake Manifold Pressure Regulation Difference Quote
If I understand your description correctly, you're experiencing insufficient boost pressure. As mentioned before, this could be due to the hoses in the control pneumatic system or the solenoid valve. However, it could also be caused by leaks in the charge air duct. Simply check the clamps and connections on the charge air duct hoses carefully. Any oil leaking out might give you a clue.
Translated on 29-08-2026, 12:57.
alca
Post19-04-2004, 20:36    Subject: Intake Manifold Pressure Regulation Difference Quote
hi
'Thank you.'
My question was only about the window settings: is the first window 'should' and the second window 'is'?
cu
I would like to post a picture here (LOG), but unfortunately, I have no idea how!
Translated on 29-08-2026, 12:58.
alca
Post12-06-2004, 22:10    Subject: Intake Manifold Pressure Regulation Difference Quote
Hello.
Okay, the error I described earlier has been fixed. Two hoses on the turbo were swapped, and now it's producing its maximum power of 2040 mbr again.
'However, I still feel like there's a lack of power (especially when starting or accelerating).'
'If I maintain a constant speed, say 60 km/h, VAG-Com shows a target value of 1100 mbar, but the actual value is only 950 mbar.'
(These are just example values to illustrate the difference.)
Could this already be the problem I'm talking about, meaning that I'm missing something?
The actual value is always below the target value by approximately 100 mbar to 200 mbar, except when operating at full load.
My thought was, 'Can this engine handle that kind of mileage (135,000 km)?'
and cause something like that?
The engine failure I experienced caused a significant amount of blue smoke to come out of the exhaust.
Thank you for your effort.
CU.
Translated on 29-08-2026, 13:00.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post13-06-2004, 2:52    Subject: Intake Manifold Pressure Regulation Difference Quote
If I maintain a constant speed, say 60 km/h, VAG-Com shows a TARGET value of 1100 mbar, but it's only reading 950 mbar.
Was für ein wert ist denn das ? Boost pressure?
The AHU only has a standard pressure of 0.9 - 1 bar icon_rolleyes.gif.
Can it be stopped when it's operating at partial load?
B.Eng (FH) u. KFZ Meister
Translated on 29-08-2026, 13:02.
Avatar-Jan6K
Post13-06-2004, 9:19    Subject: Intake Manifold Pressure Regulation Difference Quote
VAGCOM displays the value as ABSOLUTE, so 1100 mbar indicates a pressure of 0.1 bar above atmospheric pressure.
Generally, it's normal for the actual value (IST) to lag slightly behind the target value (SOLL) during acceleration. This is because the target value is calculated based on factors like engine speed, load, and throttle position, and is therefore adjusted almost instantaneously when other conditions change. However, the actual value is delayed due to the inertia of the mechanical components (e.g., turbo lag).
It's important that the "target" (SOLL) and "actual" (IST) values are relatively close to each other after the warm-up. As a test, simply accelerate from 50 to 100 in third gear with full throttle and observe the values. Initially, the "actual" value will follow the "target" value, then there will be an overshoot (IST > SOLL), and finally, it will stabilize.
Jan.
1Z5 CFHF / AHB H4D
Translated on 29-08-2026, 13:03.
porschemeister
Post13-06-2004, 20:51    Subject: Another Problem: A Different Perspective Quote
hi,
I'm new here and I hope someone can help me!
I have the exact same error code in the error memory, but in my case, the problem is excessive boost pressure.
I combined two loaders into one because the guide vanes on my old one were stuck, but now the adjustment of the push rod between the pressure chamber and the vanes doesn't seem to work properly anymore.
I've been fiddling with this thing, millimeter by millimeter, but the boost pressure is always too high!
Who else can help me? How do I adjust it? Are there any settings?
Best regards, Porsche master.
Translated on 29-08-2026, 13:05.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post13-06-2004, 23:00    Subject: Another Problem: Let's Discuss It Quote
porschemeister wrote:
hi,
greetings, Porsche master
A Wasegate loader does not have guide chutes.
And a VTG loader doesn't have a pressure vessel.
"You've put something together incorrectly."
Translated on 29-08-2026, 13:07.
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Document A6 4B, Fresh Air Blower Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3138 - Airflow Control Valve: Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intake Manifold Pressure Regulation Difference Upload
No new posts Intake Manifold Pressure: Regulation & Mass Air Flow? On-Board Diagnostics (OBD)
No new posts Intake Manifold Pressure Differential Regulation Diesel Engine Technology
No new posts Intake Manifold Pressure Error: What to Do? Diesel Engine Technology
