Always these guessing games based on sounds.
I would be concerned if it wasn't working properly, because then the turbo would be broken.
If the turbine wheel is actually rubbing against the housing, you're probably going to have the turbocharger fly off and hit you in the head soon.
You definitely mean a "pssssssssss" or a "pfffffffffffffff", right?
and that is normal.
B.Eng (FH) u. KFZ Meister
